Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Safely Remove Stickers from a Hydro Flask
Qué necesitas
    1. How to Safely Remove Stickers from a Hydro Flask, How to Safely Remove Stickers from a Hydro Flask: paso 1, imagen 1 de 1
      • Soak the water bottle in warm water for 10 minutes.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Safely Remove Stickers from a Hydro Flask: paso 2, imagen 1 de 2 How to Safely Remove Stickers from a Hydro Flask: paso 2, imagen 2 de 2
      • Dry the water bottle with a towel.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Safely Remove Stickers from a Hydro Flask: paso 3, imagen 1 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 3, imagen 2 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 3, imagen 3 de 3
      • Turn the hair dryer on high heat.
      • Apply heat to each sticker for 30 seconds.
      • Slowly peel the sticker off while applying heat.
      • Caution: Be careful not to burn your fingers when peeling off the sticker.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Safely Remove Stickers from a Hydro Flask: paso 4, imagen 1 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 4, imagen 2 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 4, imagen 3 de 3
      • Lather the water bottle in warm soapy water.
      • Scrub away at the residue with a sponge.
      • Dry down the water bottle with a towel.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Safely Remove Stickers from a Hydro Flask: paso 5, imagen 1 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 5, imagen 2 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 5, imagen 3 de 3
      • Pour the isopropyl alcohol onto a cotton pad so that it is fully soaked.
      • Using pressure, rub the residue off of the water bottle with the cotton pad.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Safely Remove Stickers from a Hydro Flask: paso 6, imagen 1 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 6, imagen 2 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 6, imagen 3 de 3
      • Scrape off the residue with a card. Scrape up to down.
      • Scrape from right to left.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Safely Remove Stickers from a Hydro Flask: paso 7, imagen 1 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 7, imagen 2 de 3 How to Safely Remove Stickers from a Hydro Flask: paso 7, imagen 3 de 3
      • Coat a cotton swab in the isopropyl alcohol.
      • With pressure, rub off the residue with the cotton swab.
      • For any difficult residue follow this step.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Safely Remove Stickers from a Hydro Flask: paso 8, imagen 1 de 2 How to Safely Remove Stickers from a Hydro Flask: paso 8, imagen 2 de 2
      • Enjoy your new water bottle!
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Karley Makar
Miembro Desde 11/05/24
157 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-5, Vidal-Chiesa Fall 2024 Miembro de UC Davis, Team 4-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G5
Miembros de 2
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 38
Ultimos 30 días: 148
Todo El Tiempo: 1,046
