Saltar al contenido principal
How to Restore a Used Canvas
Qué necesitas
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: paso 1, imagen 1 de 2 How to Restore a Used Canvas, How to Restore a Used Canvas: paso 1, imagen 2 de 2
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: paso 2, imagen 1 de 2 How to Restore a Used Canvas: paso 2, imagen 2 de 2
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: paso 3, imagen 1 de 1
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: paso 4, imagen 1 de 3 How to Restore a Used Canvas: paso 4, imagen 2 de 3 How to Restore a Used Canvas: paso 4, imagen 3 de 3
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: paso 5, imagen 1 de 1
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: paso 6, imagen 1 de 1
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: paso 7, imagen 1 de 3 How to Restore a Used Canvas: paso 7, imagen 2 de 3 How to Restore a Used Canvas: paso 7, imagen 3 de 3
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: paso 8, imagen 1 de 3 How to Restore a Used Canvas: paso 8, imagen 2 de 3 How to Restore a Used Canvas: paso 8, imagen 3 de 3
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
Linea de Meta
Sandra Henriquez
Miembro Desde 04/21/21
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 781
