Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Restore a Damaged Cork Board
Qué necesitas
  1. How to Restore a Damaged Cork Board, How to Restore a Damaged Cork Board: paso 1, imagen 1 de 1
    • Cover your work surface with a tarp.
  2. How to Restore a Damaged Cork Board: paso 2, imagen 1 de 1
    • Use a rag, soap, and water to scrub the damaged area to remove residual pieces of cork and glue.
    • Allow the area to dry.
  3. How to Restore a Damaged Cork Board: paso 3, imagen 1 de 1
    • Apply wood filler liberally on top of the holes.
  4. How to Restore a Damaged Cork Board: paso 4, imagen 1 de 2 How to Restore a Damaged Cork Board: paso 4, imagen 2 de 2
    • Smooth out the wood filler using a putty knife.
    • Hold the putty knife at an angle and use long strokes to flatten the filler as much as possible.
    • Wait 1 hour for the filler to dry.
  5. How to Restore a Damaged Cork Board: paso 5, imagen 1 de 1
    • Use 80-grit sandpaper to sand down the excess filler in a circular motion.
  6. How to Restore a Damaged Cork Board: paso 6, imagen 1 de 1
    • Cover the damaged area with a thin, even layer of wood sealant.
Conclusión
This guide will help you keep your old cork boards instead of trying to replace them. I hope you found our guide useful.
Una persona más ha completado esta guía.
Annie Wilson
Miembro Desde 09/27/23
154 Reputación
1 Guía escrita
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 94
Todo El Tiempo: 2,462
