Saltar al contenido principal
How to Restore An Expo Marker
Qué necesitas
  1. How to Restore  An Expo Marker, How to Restore  An Expo Marker: paso 1, imagen 1 de 1
    • Collect all of the markers you want to restore.
    • Obtain isopropyl alcohol (rubbing alcohol) or vinegar.
  2. How to Restore  An Expo Marker: paso 2, imagen 1 de 1
    • Pour a small amount of either alcohol or vinegar into a small bowl, using enough to cover the tip of the markers.
    • Soak the tip of the markers in the alcohol or vinegar until the ink comes out of the tip of the marker.
    • In some cases, you will see the ink of the marker swirl out.
  3. How to Restore  An Expo Marker: paso 3, imagen 1 de 2 How to Restore  An Expo Marker: paso 3, imagen 2 de 2
    • Place the cap back on the marker.
    • Let the marker sit tip side up for at least 24 hours. The alcohol should penetrate inside the tip of the marker.
  4. How to Restore  An Expo Marker: paso 4, imagen 1 de 1
    • Your marker should be good to go.
    • If your marker is not functioning properly, it may be a sign that your marker dried out completely.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 63
Ultimos 7 días: 538
Ultimos 30 días: 2,236
Todo El Tiempo: 19,623
