Saltar al contenido principal
How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard
Qué necesitas
  1. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard, How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 1, imagen 1 de 1
    • Unplug the computer from the power supply before disassembly.
    • Wait 5 minutes after the device has been powered off.
  2. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 2, imagen 1 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 2, imagen 2 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 2, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove two screws that would grant access to inner components of your computer.
    • Remove the side panel of the computer tower to access the inner components. Slide the panel then lift it to safely remove it.
    • Removing the panel may be different for your computer.
  3. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 3, imagen 1 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 3, imagen 2 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 3, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the screw holding the graphics card (GPU) onto the motherboard.
    • Disconnect any power cables that may be attached to your graphics card.
    • Carefully slide the graphics card out from its slot.
  4. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 4, imagen 1 de 2 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 4, imagen 2 de 2
    • Remove the CMOS Battery using a plastic opening tool.
    • There may be a spring mechanism available to use to easily remove the battery.
  5. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 5, imagen 1 de 1
    • Wait 5 minutes to allow enough time for the power to cycle through.
  6. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: paso 6, imagen 1 de 1
    • Insert battery back into position with the flat side facing upwards.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 133
Todo El Tiempo: 4,662
