Saltar al contenido principal
How to Repress a Broken Makeup Compact
Qué necesitas
  1. How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: paso 1, imagen 1 de 2 How to Repress a Broken Makeup Compact, How to Repress a Broken Makeup Compact: paso 1, imagen 2 de 2
    • If some of the product remains unbroken, break it down using a toothpick . Completely crush the powder for a smooth fix.
  2. How to Repress a Broken Makeup Compact: paso 2, imagen 1 de 2 How to Repress a Broken Makeup Compact: paso 2, imagen 2 de 2
    • Add a few drops of rubbing alcohol to the broken product (the amount differs based on how much product you have left) and then thoroughly mix the alcohol into the powder with a toothpick.
  3. How to Repress a Broken Makeup Compact: paso 3, imagen 1 de 1
    • Place plastic wrap over the product and pull taut to reduce wrinkles in the plastic wrap.
  4. How to Repress a Broken Makeup Compact: paso 4, imagen 1 de 2 How to Repress a Broken Makeup Compact: paso 4, imagen 2 de 2
    • Press and smooth the product out using your finger or a spoon.
    • This may take some patience depending on how smooth you would like your product to turn out.
  5. How to Repress a Broken Makeup Compact: paso 5, imagen 1 de 1
    • Once smoothed, remove the plastic wrap and allow the compact to dry for 6-8 hours.
    • Pro tip: If you need to use your product soon, you can speed up drying time by using a hairdryer on low heat!
  6. How to Repress a Broken Makeup Compact: paso 6, imagen 1 de 2 How to Repress a Broken Makeup Compact: paso 6, imagen 2 de 2
    • Lastly, enjoy your product! It provides the same pigment and performance as it once did before the break.
Conclusión
This method will save you money and preserve your favorite powder products without compromising its quality or pigment. I hope you found my guide useful.
Your friendly makeup lover,
Alexis
2 personas más completaron esta guía.
Alexis Wilhelm
Miembro Desde 05/01/20
181 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 13
Ultimos 30 días: 59
Todo El Tiempo: 3,168
