Saltar al contenido principal
How to Replace the Xbox 360 Optical Drive Belt
Qué necesitas
  1. How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: paso 1, imagen 1 de 2 How to Replace the Xbox 360 Optical Drive Belt, Optical Drive Belt: paso 1, imagen 2 de 2
    • Remove the hard drive.
  2. How to Replace the Xbox 360 Optical Drive Belt: paso 2, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 2, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 2, imagen 3 de 3
    • Use a pry tool to gently remove the faceplate from the Xbox.
  3. How to Replace the Xbox 360 Optical Drive Belt: paso 3, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 3, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 3, imagen 3 de 3
    • Press down on the three holes as indicated to release the clips securing the base plate.
    • Remove the base plate.
    • Repeat this step on the other side.
  4. How to Replace the Xbox 360 Optical Drive Belt: paso 4, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 4, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 4, imagen 3 de 3
    • Repeat the previous step to remove the top plate of the Xbox.
  5. How to Replace the Xbox 360 Optical Drive Belt: paso 5, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 5, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 5, imagen 3 de 3
    • Gently unhook all four clips located on the front of the Xbox.
    • Take care not to break the plastic clips; it may be fragile.
  6. How to Replace the Xbox 360 Optical Drive Belt: paso 6, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 6, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 6, imagen 3 de 3
    • Use the flathead screwdriver to gently press down on all of the indicated indents.
    • Remove the top casing from the Xbox.
  7. How to Replace the Xbox 360 Optical Drive Belt: paso 7, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 7, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 7, imagen 3 de 3
    • Use the T3 Torx screwdriver to remove all six screws.
  8. How to Replace the Xbox 360 Optical Drive Belt: paso 8, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 8, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 8, imagen 3 de 3
    • Carefully flip over the Xbox to the other side.
    • Lift the Xbox casing off.
  9. How to Replace the Xbox 360 Optical Drive Belt: paso 9, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 9, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 9, imagen 3 de 3
    • Unplug the two connections in the rear of the disk drive.
  10. How to Replace the Xbox 360 Optical Drive Belt: paso 10, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 10, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 10, imagen 3 de 3
    • Use a flat screwdriver to remove the four screws underneath the disc drive.
    • Flip over the DVD disc drive and remove the casing.
  11. How to Replace the Xbox 360 Optical Drive Belt: paso 11, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 11, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Spin the located area with the flathead screwdriver to open up the disc drive.
    • Use tweezers to remove the belt drive.
  12. How to Replace the Xbox 360 Optical Drive Belt: paso 12, imagen 1 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 12, imagen 2 de 3 How to Replace the Xbox 360 Optical Drive Belt: paso 12, imagen 3 de 3
    • Replace with a new drive belt.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 49
Ultimos 30 días: 301
Todo El Tiempo: 3,190
