Saltar al contenido principal
How to Replace the Wheels on an Office Chair
Qué necesitas
  1. How to Replace the Wheels on an Office Chair, Removing Casters: paso 1, imagen 1 de 1
    • Lay the chair down.
    • If the chair is too heavy to turn upside down, have someone help you do it.
  2. How to Replace the Wheels on an Office Chair: paso 2, imagen 1 de 1
    • Wipe the stem of the caster with a rag or paper towel to remove any dust or debris.
  3. How to Replace the Wheels on an Office Chair: paso 3, imagen 1 de 3 How to Replace the Wheels on an Office Chair: paso 3, imagen 2 de 3 How to Replace the Wheels on an Office Chair: paso 3, imagen 3 de 3
    • Use a flathead screwdriver in between the caster and the base of the chair to pry the wheel out of the socket.
    • Turn the screwdriver gently until the caster starts to move upwards away from the chair.
    • Try rotating the screwdriver at different angles if the caster won't come out.
  4. How to Replace the Wheels on an Office Chair: paso 4, imagen 1 de 3 How to Replace the Wheels on an Office Chair: paso 4, imagen 2 de 3 How to Replace the Wheels on an Office Chair: paso 4, imagen 3 de 3
    • Use a prying tool that is big enough to fit between the caster and over the stem.
    • Gently pull on the caster upwards and it should come off.
  5. How to Replace the Wheels on an Office Chair: paso 5, imagen 1 de 2 How to Replace the Wheels on an Office Chair: paso 5, imagen 2 de 2
    • Measure the wheel's height and length.
    • Once you've done that, purchase your new casters.
    • Large casters(about 3"), are more durable and versatile. Twin-wheel casters are usually used in office settings.
  6. How to Replace the Wheels on an Office Chair: paso 6, imagen 1 de 2 How to Replace the Wheels on an Office Chair: paso 6, imagen 2 de 2
    • Push the caster's stem into the bottom of chair leg.
    • Install the new casters.
Linea de Meta
Una persona más ha completado esta guía.
Ismail Dhorre
Miembro Desde 01/10/21
160 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 26
Ultimos 30 días: 116
Todo El Tiempo: 5,674
