Saltar al contenido principal
How to Replace the Pom Pom on a Beanie
Qué necesitas
  1. How to Replace the Pom Pom on a Beanie, Beanie Pom Pom: paso 1, imagen 1 de 1
    • Use sewing scissors to cut the string that attaches the pom pom to the beanie if it's still loosely attached.
  2. How to Replace the Pom Pom on a Beanie: paso 2, imagen 1 de 2 How to Replace the Pom Pom on a Beanie: paso 2, imagen 2 de 2
    • Measure 10 inches of yarn.
    • Use your scissors to cut the yarn.
  3. How to Replace the Pom Pom on a Beanie: paso 3, imagen 1 de 3 How to Replace the Pom Pom on a Beanie: paso 3, imagen 2 de 3 How to Replace the Pom Pom on a Beanie: paso 3, imagen 3 de 3
    • Pull one end of the yarn through the eye of a hand sewing needle until you have an even amount of yarn on both sides of the needle.
    • The point of the needle is sharp enough to pierce skin.
  4. How to Replace the Pom Pom on a Beanie: paso 4, imagen 1 de 3 How to Replace the Pom Pom on a Beanie: paso 4, imagen 2 de 3 How to Replace the Pom Pom on a Beanie: paso 4, imagen 3 de 3
    • Push the needle through the pom pom, leaving a 3 inch tail of yarn.
    • Be aware of where the needle will exit and where your hand is holding the pom pom.
  5. How to Replace the Pom Pom on a Beanie: paso 5, imagen 1 de 3 How to Replace the Pom Pom on a Beanie: paso 5, imagen 2 de 3 How to Replace the Pom Pom on a Beanie: paso 5, imagen 3 de 3
    • Poke the pom pom with the point of the needle at the same place you poked it in Step 4.
    • Pull the needle all the way through and keep the yarn on the needle.
    • You will end up with two strands of yarn, one on each side of the pom pom.
  6. How to Replace the Pom Pom on a Beanie: paso 6, imagen 1 de 3 How to Replace the Pom Pom on a Beanie: paso 6, imagen 2 de 3 How to Replace the Pom Pom on a Beanie: paso 6, imagen 3 de 3
    • Push the needle through the top of the beanie.
    • Pull the needle all the way through until the pom pom is fixed against the beanie.
  7. How to Replace the Pom Pom on a Beanie: paso 7, imagen 1 de 3 How to Replace the Pom Pom on a Beanie: paso 7, imagen 2 de 3 How to Replace the Pom Pom on a Beanie: paso 7, imagen 3 de 3
    • Push the needle all the way through one of the holes of the button.
    • Keep button in place and remove the needle from the yarn.
  8. How to Replace the Pom Pom on a Beanie: paso 8, imagen 1 de 3 How to Replace the Pom Pom on a Beanie: paso 8, imagen 2 de 3 How to Replace the Pom Pom on a Beanie: paso 8, imagen 3 de 3
    • Put the second strand of yarn through the eye of the needle.
    • Poke the needle through the top of the beanie again.
    • Pull the remaining yarn all the way through to the other side of the beanie.
  9. How to Replace the Pom Pom on a Beanie: paso 9, imagen 1 de 3 How to Replace the Pom Pom on a Beanie: paso 9, imagen 2 de 3 How to Replace the Pom Pom on a Beanie: paso 9, imagen 3 de 3
    • Pull the yarn all the way through another hole in the button.
  10. How to Replace the Pom Pom on a Beanie: paso 11, imagen 1 de 2 How to Replace the Pom Pom on a Beanie: paso 11, imagen 2 de 2
    • Tie another overhand knot.
  11. How to Replace the Pom Pom on a Beanie: paso 12, imagen 1 de 2 How to Replace the Pom Pom on a Beanie: paso 12, imagen 2 de 2
    • Cut off the remaining ends of the yarn, cutting close to the button.
Linea de Meta
Erin Shea
Miembro Desde 01/26/23
205 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-4, Morris Winter 2023 Miembro de UC Davis, Team 2-4, Morris Winter 2023
UCD-MORRIS-W23S2G4
2 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 62
Todo El Tiempo: 912
