Saltar al contenido principal
How to Replace the Headlight in a 2010-2014 Volkswagen Jetta
Qué necesitas
  1. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: paso 1, imagen 1 de 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: paso 1, imagen 2 de 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: paso 1, imagen 3 de 3
    • Turn the ignition fully off and open the hood of your vehicle.
    • The lever to open it is on the left hand side of the pedals. It’ll make a noticeable clunk sound when pulled the first time which releases the first of the two step hood opening procedure.
    • Make your way to the front of the car and push up on the lever underneath the hood to fully open the hood.
    • Use the hood prop rod to hold the hood open for the duration of the repair.
  2. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: paso 2, imagen 1 de 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: paso 2, imagen 2 de 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: paso 2, imagen 3 de 3
    • Locate the plastic dust cover behind the burnt headlight and gently remove it. If the cover is stuck, you can use a screwdriver to pop it out.
  3. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: paso 3, imagen 1 de 2 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: paso 3, imagen 2 de 2
    • Once the cover is off, twist the light harness from the fixture in a counter clockwise rotation.
    • Pull the bulb to separate it from the connector.
    • Insert the new bulb in the correct orientation as the previous, and tighten it back into the headlight by rotating it clockwise.
  4. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: paso 4, imagen 1 de 1
    • Reapply the dust cover and close the hood of the vehicle.
  5. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: paso 5, imagen 1 de 1
    • Turn the ignition on and switch on the lights to test the new working headlight.
Conclusión
To replace the other headlight. follow the same instructions.
Seyed-Mohammad Hosseiny
Miembro Desde 09/22/20
159 Reputación
1 Guía escrita
Equipo
6 comentarios
Am I missing something? Or is there a trick to those tabs to release the bulb?
Dez Petrovic - Contestar
They are a pull to release mechanism. no need to undo tabs.
Seyed-Mohammad Hosseiny -
Don’t forget to wear gloves when handling halogen light bulbs!
Where’s the driving lights?
Ted Stoffers - Contestar
I installed the new bulb but it still doesn’t work. My neighbor, a retired mechanic came to help and undid both and put back and now, both headlights don’t work. Any other advice?
Emilia Lievano - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 112
Ultimos 30 días: 488
Todo El Tiempo: 21,158
