Saltar al contenido principal
How to Replace the GPU on a Dell OptiPlex 9010
Qué necesitas
  1. How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: paso 1, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: paso 1, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010, Graphics Card: paso 1, imagen 3 de 3
    • Before getting started, make sure to shut down and unplug all cables from your computer.
    • Place the computer on a flat surface.
  2. How to Replace the GPU on a Dell OptiPlex 9010: paso 2, imagen 1 de 2 How to Replace the GPU on a Dell OptiPlex 9010: paso 2, imagen 2 de 2
    • Lay the computer on its side, on the flat surface.
    • Use a Phillips #2 screwdriver to remove any screws holding the side panel in place.
    • Use the handle on the side panel to pull it up to remove it.
  3. How to Replace the GPU on a Dell OptiPlex 9010: paso 3, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 3, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 3, imagen 3 de 3
    • Grip the side panel with both hands to fully remove it. This will give you a complete look into the internal hardware.
    • Be sure to touch the metal casing inside to ground yourself. Otherwise, you might accidentally damage the components from the static electricity your body builds up.
  4. How to Replace the GPU on a Dell OptiPlex 9010: paso 4, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 4, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 4, imagen 3 de 3
    • Push down on the release tab on the card retention latch to free the existing (old) graphics card.
  5. How to Replace the GPU on a Dell OptiPlex 9010: paso 5, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 5, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 5, imagen 3 de 3
    • Unlatch the PCIE clip. Gently remove the existing graphics card to make sure there are no cables caught.
  6. How to Replace the GPU on a Dell OptiPlex 9010: paso 6, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 6, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 6, imagen 3 de 3
    • Now grab your replacement GPU (graphics card).
  7. How to Replace the GPU on a Dell OptiPlex 9010: paso 7, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 7, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 7, imagen 3 de 3
    • Add or remove expansion slot covers based on the number of slots your new graphics card requires.
  8. How to Replace the GPU on a Dell OptiPlex 9010: paso 8, imagen 1 de 2 How to Replace the GPU on a Dell OptiPlex 9010: paso 8, imagen 2 de 2
    • Firmly place the new GPU on the bus (into the slot). Reclip the PCIE clamp to hold it into place.
  9. How to Replace the GPU on a Dell OptiPlex 9010: paso 9, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 9, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 9, imagen 3 de 3
    • Check to make sure the new GPU card is properly positioned to fit with the screw holes and expansion slots.
  10. How to Replace the GPU on a Dell OptiPlex 9010: paso 10, imagen 1 de 2 How to Replace the GPU on a Dell OptiPlex 9010: paso 10, imagen 2 de 2
    • Screw in any 6-32 Phillips screws (any that are from 1/4 to 1/2 inch long) with your Phillips screwdriver to properly secure your new GPU card.
  11. How to Replace the GPU on a Dell OptiPlex 9010: paso 11, imagen 1 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 11, imagen 2 de 3 How to Replace the GPU on a Dell OptiPlex 9010: paso 11, imagen 3 de 3
    • Pull up on the release tab on the card retention latch to secure the card.
  12. How to Replace the GPU on a Dell OptiPlex 9010: paso 12, imagen 1 de 2 How to Replace the GPU on a Dell OptiPlex 9010: paso 12, imagen 2 de 2
    • Line the side panel up with the clamps and push it down to reattach the panel.
  13. How to Replace the GPU on a Dell OptiPlex 9010: paso 13, imagen 1 de 2 How to Replace the GPU on a Dell OptiPlex 9010: paso 13, imagen 2 de 2
    • Use your Phillips #2 screwdriver to replace the screws and secure the side panel.
Linea de Meta
Michael Cortez
Miembro Desde 09/19/22
217 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 33
Todo El Tiempo: 761
