Introducción
Brakes are one of the most important components on any motorcycle. If your brakes are getting near the end of their life, or you are looking for a brake pad upgrade, this guide will show you how to disassemble your front calipers and replace the brake pads.
Qué necesitas
Place the motorcycle on its center stand to keep the bike upright and stable. If your motorcycle doesn’t have an attached center stand, use a wheel chock or a race stand (front or rear). The kickstand is usable, but will reduce accessibility to the left caliper.
With the bracket extended upwards, hook the end of the brake pad on the retainer clip so the friction pad faces inward, and the hole on the opposite side lines up with the hole for the retainer pin.
Rotate the bracket down. This will cause the retainer clip to clamp down on the edge of the pads.
Thread the bracket nut back into the bracket.
Place the caliper so that the brake rotor fits in between the pads.
Line up the bracket with the mount on the forks, and using the two 12mm bolts you set aside previously, attach the bracket to the mount. Using a torque wrench, torque the bolts to 17-22 ft-lbs (24-30 N*m)
If you haven't done so already, re-attach the retainer pin cap with a flathead screwdriver.
To replace opposite side brake pads, follow the same procedure.
3 personas más completaron esta guía.
Un comentario
Zach Ell: for a latin american, this a priceless professional tool. G. bless your generations forever. Thank so much.
