Saltar al contenido principal
How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
Qué necesitas
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: paso 1, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: paso 1, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: paso 1, imagen 3 de 3
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 2, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 2, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 2, imagen 3 de 3
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 3, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 3, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 3, imagen 3 de 3
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 4, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 4, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 4, imagen 3 de 3
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 5, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 5, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 5, imagen 3 de 3
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 6, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 6, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 6, imagen 3 de 3
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 7, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 7, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 7, imagen 3 de 3
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 8, imagen 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 8, imagen 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: paso 8, imagen 3 de 3
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
Conclusión
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 51
Todo El Tiempo: 294
