Saltar al contenido principal
How to Replace the Arm of Standard Hinge Eyeglasses
Qué necesitas
  1. How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: paso 1, imagen 1 de 2 How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: paso 1, imagen 2 de 2
    • Remove the screw holding the broken arm by turning it counterclockwise.
  2. How to Replace the Arm of Standard Hinge Eyeglasses: paso 2, imagen 1 de 1
    • Carefully set the screw aside and discard the broken arm.
  3. How to Replace the Arm of Standard Hinge Eyeglasses: paso 3, imagen 1 de 1
    • Thoroughly clean the screw and the connecting hinge using the cleaning cloth to remove any dirt or buildup.
  4. How to Replace the Arm of Standard Hinge Eyeglasses: paso 4, imagen 1 de 2 How to Replace the Arm of Standard Hinge Eyeglasses: paso 4, imagen 2 de 2
    • Align the joints of the new arm with the joint connected to the frame.
    • The frame joint should be in between the two joints of the arm.
  5. How to Replace the Arm of Standard Hinge Eyeglasses: paso 5, imagen 1 de 3 How to Replace the Arm of Standard Hinge Eyeglasses: paso 5, imagen 2 de 3 How to Replace the Arm of Standard Hinge Eyeglasses: paso 5, imagen 3 de 3
    • Insert the screw in the hinge and lightly tighten by turning the screw clockwise.
    • Make sure all parts are aligned and that the new arm is not angled.
    • You may want to put the glasses on to make sure the arm is positioned properly.
  6. How to Replace the Arm of Standard Hinge Eyeglasses: paso 6, imagen 1 de 1
    • Once aligned, fully tighten the screw.
    • You may need to make adjustments to the tightness of the arm. Tighten (turn clockwise) or loosen (turn counterclockwise) the screw until you have a comfortable fit.
Linea de Meta
Una persona más ha completado esta guía.
Mariam
Miembro Desde 01/16/23
163 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 81
Ultimos 30 días: 252
Todo El Tiempo: 2,390
