Saltar al contenido principal
How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier
Qué necesitas
  1. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier, Air Filter: paso 1, imagen 1 de 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier, Air Filter: paso 1, imagen 2 de 2
    • Press the ON/OFF button to power off the machine.
    • The machine is off when the LED light above the ON/OFF button is red.
  2. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 2, imagen 1 de 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 2, imagen 2 de 2
    • Remove the power cord from the back of the machine.
  3. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 3, imagen 1 de 3 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 3, imagen 2 de 3 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 3, imagen 3 de 3
    • On the bottom of the machine, turn the filter cover counter-clockwise.
    • Remove the filter cover.
  4. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 4, imagen 1 de 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 4, imagen 2 de 2
    • Remove the filter from the filter compartment.
  5. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 5, imagen 1 de 1
    • Using the can of compressed air, spray any loose dust out of the empty filter compartment.
  6. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 6, imagen 1 de 1
    • Using a sanitizer wipe, wipe down the inside of the empty filter compartment.
  7. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 7, imagen 1 de 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 7, imagen 2 de 2
    • On the top of the machine, remove the fan cover.
    • Unlike the filter cover, the fan cover can be pried straight off without turning it.
  8. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: paso 8, imagen 1 de 1
    • Using the can of compressed air, spray any dust out of the fan compartment.
Conclusión
To reassemble the air purifier machine, follow these instructions in reverse order.
4 comentarios
Does the gadget tells it’s user it’s time to replace it’s air filter? I mean it looks small though to clean and filter the air around it’s surroundings.
Yul Cababan - Contestar
What do 16 beeps mean? Is there a downloadable manual in English to tell me this stuff?
Bruce shier - Contestar
Well is there a manual?
William Bravenec -
Did anyone find a manual for the Partu BS-03 air purifier? I have changed the filter, and reset the filter button. I still hear 3 rapid beeps every 5-10 minutes. Anyone have any insight?
Michael Ratliff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 36
Ultimos 30 días: 139
Todo El Tiempo: 6,013
