Saltar al contenido principal
How to Replace a Window Arm for an Out-Swinging Casement Window
Qué necesitas
  1. How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: paso 1, imagen 1 de 2 How to Replace a Window Arm for an Out-Swinging Casement Window, Window Arm: paso 1, imagen 2 de 2
    • Unlock the window lock by flipping both switches up until they are pointed horizontally outwards, facing the user.
  2. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 2, imagen 1 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 2, imagen 2 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 2, imagen 3 de 3
    • Pull open all four metal screen latches holding the window screen in place.
    • Place hands on both sides of the screen and lift upwards to remove it.
    • In some cases only two screen latches need to be unlocked for the screen to become loose enough to remove.
  3. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 3, imagen 1 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 3, imagen 2 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 3, imagen 3 de 3
    • Turn the window handle clockwise to open the window.
  4. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 4, imagen 1 de 1
    • Use a flathead screwdriver in a clockwise direction to remove the 2.11 mm screw from the bottom of the window handle.
  5. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 5, imagen 1 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 5, imagen 2 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 5, imagen 3 de 3
    • Turn the loosened window handle in either direction to remove it.
  6. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 6, imagen 1 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 6, imagen 2 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 6, imagen 3 de 3
    • Detach the window arm from the track running underneath the window.
    • In most cases window arm has already been detached, so this step would be skipped.
  7. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 7, imagen 1 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 7, imagen 2 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 7, imagen 3 de 3
    • Using a Square #0 screwdriver, remove the four 25.4 mm screws placed on the outside of the window sill.
  8. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 8, imagen 1 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 8, imagen 2 de 3 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 8, imagen 3 de 3
    • Pull the body of the window operator which when removed will vacate a slot.
    • Pull the window arm diagonally through the slot.
  9. How to Replace a Window Arm for an Out-Swinging Casement Window: paso 9, imagen 1 de 2 How to Replace a Window Arm for an Out-Swinging Casement Window: paso 9, imagen 2 de 2
    • Insert the new window operator into the slot, ensuring it is tightly fit into place.
    • Attach a replacement window arm to the track on the bottom of the window panel.
Conclusión
Nabil Patel
Miembro Desde 01/08/21
169 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 27
Ultimos 30 días: 119
Todo El Tiempo: 1,692
