Saltar al contenido principal
How to Replace a Valve Spring on a Trumpet
Qué necesitas
  1. How to Replace a Valve Spring on a Trumpet, valve spring: paso 1, imagen 1 de 2 How to Replace a Valve Spring on a Trumpet, valve spring: paso 1, imagen 2 de 2
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: paso 2, imagen 1 de 2 How to Replace a Valve Spring on a Trumpet: paso 2, imagen 2 de 2
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: paso 3, imagen 1 de 2 How to Replace a Valve Spring on a Trumpet: paso 3, imagen 2 de 2
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
Conclusión
Una persona más ha completado esta guía.
Isaac Trotta
Miembro Desde 02/24/15
125 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 23-4, Green Winter 2015 Miembro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
Miembros de 7
15 Guías creadas
1Guía Comentario
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 39
Todo El Tiempo: 8,928
