Saltar al contenido principal
How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass
Qué necesitas
  1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: paso 1, imagen 1 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: paso 1, imagen 2 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: paso 1, imagen 3 de 3
    • Turn the tuning key counter-clockwise to the loosen string.
    • Only loosen the turning key(s) that need to be replaced.
    • Continue turning until there is slack in the string.
  2. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 2, imagen 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 2, imagen 2 de 2
    • Cut the desired string with needle nose pliers.
    • Make sure the string has slack before cutting.
    • Remove the string by threading out through the bottom of the bass.
  3. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 3, imagen 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 3, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the four 9.53 mm screws.
    • Remove the broken tuning key.
  4. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 4, imagen 1 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 4, imagen 2 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 4, imagen 3 de 3
    • Adjust the direction of the replacement tuning key as need.
    • Line up the screw holes of the tuning key to the existing drill holes on the bass.
  5. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 5, imagen 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 5, imagen 2 de 2
    • Note the length of the tuning key securing screws to estimate the drill depth needed to drill into the headstock.
    • Drill new placement holes into the headstock using a 1/16" drill bit.
    • Drill in a level environment and be aware of surroundings.
    • Drill the holes straight down and centered with the tuning key screw holes.
  6. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 6, imagen 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 6, imagen 2 de 2
    • Secure the four 9.58 mm screws using a drill with the Phillips #2 screwdriver bit.
    • Make sure the drill is not held at an angle to prevent the screws from stripping.
  7. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 7, imagen 1 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 7, imagen 2 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: paso 7, imagen 3 de 3
    • Thread the string through the bottom of the bass to the new tuning key.
    • Loop the string around the tuning peg-three to four times-until tight.
    • Check for tension in the string.
    • Adjust the tuning key as needed.
Conclusión
This guide will work for any of the tuning keys on a Sterling by Music Man StingRay.
Darby Eime
Miembro Desde 02/13/23
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 344
