Saltar al contenido principal
How to Replace a Transition Strip (T Molding)
Qué necesitas
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): paso 1, imagen 1 de 1
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): paso 2, imagen 1 de 3 How to Replace a Transition Strip (T Molding): paso 2, imagen 2 de 3 How to Replace a Transition Strip (T Molding): paso 2, imagen 3 de 3
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): paso 3, imagen 1 de 3 How to Replace a Transition Strip (T Molding): paso 3, imagen 2 de 3 How to Replace a Transition Strip (T Molding): paso 3, imagen 3 de 3
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): paso 4, imagen 1 de 2 How to Replace a Transition Strip (T Molding): paso 4, imagen 2 de 2
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): paso 5, imagen 1 de 1
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): paso 6, imagen 1 de 3 How to Replace a Transition Strip (T Molding): paso 6, imagen 2 de 3 How to Replace a Transition Strip (T Molding): paso 6, imagen 3 de 3
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): paso 7, imagen 1 de 2 How to Replace a Transition Strip (T Molding): paso 7, imagen 2 de 2
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
Conclusión
Rojean Noorinayer
Miembro Desde 05/12/21
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 26
Ultimos 30 días: 149
Todo El Tiempo: 4,505
