Saltar al contenido principal
How to Replace a Tail Light for a 2011-2015 Ford Explorer
Qué necesitas
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: paso 1, imagen 1 de 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: paso 1, imagen 2 de 2
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 2, imagen 1 de 1
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 3, imagen 1 de 1
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 4, imagen 1 de 1
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 5, imagen 1 de 1
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 6, imagen 1 de 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 6, imagen 2 de 2
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 7, imagen 1 de 1
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 8, imagen 1 de 1
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 9, imagen 1 de 1
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: paso 10, imagen 1 de 1
    • Gently place the new bulb in the bulb socket.
Conclusión
8 personas más completaron esta guía.
Michael Lynch
Miembro Desde 09/29/15
317 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-4, Green Fall 2015 Miembro de Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Miembros
16 Guías creadas
Un comentario
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 87
Todo El Tiempo: 21,833
