Saltar al contenido principal
How to Replace a Skateboard Deck
Qué necesitas
  1. How to Replace a Skateboard Deck, Deck: paso 1, imagen 1 de 1
    • Use the 3/8" socket to take off the nut
    • Use the phillips side to hold the screw in place.
    • Remove the nut
    • Repeat for all four nuts on the truck
    • Repeat for the second truck
  2. How to Replace a Skateboard Deck: paso 2, imagen 1 de 2 How to Replace a Skateboard Deck: paso 2, imagen 2 de 2
    • Remove both trucks from the board
    • Remove all 8 screws
  3. How to Replace a Skateboard Deck: paso 3, imagen 1 de 3 How to Replace a Skateboard Deck: paso 3, imagen 2 de 3 How to Replace a Skateboard Deck: paso 3, imagen 3 de 3
    • Line up the grip with the board
    • Ensure it covers the entirety of the board and hangs over the edge
    • Peel the back off at one end enough to reveal the sticky side.
    • Expose about four inches
    • Attach the peeled side to one end of the board
    • Press the grip onto the board slowly and work your way across the board
    • Ensure that there is no air bubbles forming when applying the grip
  4. How to Replace a Skateboard Deck: paso 4, imagen 1 de 2 How to Replace a Skateboard Deck: paso 4, imagen 2 de 2
    • Use the phillips head screwdriver to trace the edge of the board
    • Ensure it can be seen all the way around the board
  5. How to Replace a Skateboard Deck: paso 5, imagen 1 de 1
    • Trim the grip along the trace you made with the box cutter
    • Use long and smooth motions for straight trims
    • Trim up the jagged edges left on the grip on the edge of the board
  6. How to Replace a Skateboard Deck: paso 6, imagen 1 de 1
    • Sand the edges with the left over grip
    • This is to ensure the grip fully applies to the board
  7. How to Replace a Skateboard Deck: paso 7, imagen 1 de 2 How to Replace a Skateboard Deck: paso 7, imagen 2 de 2
    • Poke a hole with the screw from the bottom of the deck
    • Remove the screw
    • Insert it through the top on the deck
    • Repeat for all 4 holes
    • Repeat on the opposite side with the other truck
  8. How to Replace a Skateboard Deck: paso 8, imagen 1 de 3 How to Replace a Skateboard Deck: paso 8, imagen 2 de 3 How to Replace a Skateboard Deck: paso 8, imagen 3 de 3
    • Use the 3/8" socket to screw on the nut
    • The hangar should face outwards
    • Tighten them until they're snug
    • Overtightening can damage the deck
Linea de Meta
Dylan Norris
Miembro Desde 10/06/22
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 29
Todo El Tiempo: 614
