Saltar al contenido principal
How to Replace a Screen Protector on an iPhone 12
Qué necesitas
  1. How to Replace a Screen Protector on an iPhone 12, Screen Protector: paso 1, imagen 1 de 3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: paso 1, imagen 2 de 3 How to Replace a Screen Protector on an iPhone 12, Screen Protector: paso 1, imagen 3 de 3
    • If you already have a pre-existing screen protector, you will gently peel of your existing screen protector from the top of you iPhone.
    • If any small pieces of the screen protector are still attached to the phone, genlty peel the pieces off until no more pieces remain.
    • When the screen protector and the pieces are removed, you can dispose of it immediately or set it aside for disposal.
  2. How to Replace a Screen Protector on an iPhone 12: paso 2, imagen 1 de 3 How to Replace a Screen Protector on an iPhone 12: paso 2, imagen 2 de 3 How to Replace a Screen Protector on an iPhone 12: paso 2, imagen 3 de 3
    • Grab the wet cloth from the pack and wipe the screen of the iPhone in order to remove any stain or mark left behind.
  3. How to Replace a Screen Protector on an iPhone 12: paso 3, imagen 1 de 2 How to Replace a Screen Protector on an iPhone 12: paso 3, imagen 2 de 2
    • With the LCD cloth, wipe and dry the screen of the phone to remove any small debris or dust.
  4. How to Replace a Screen Protector on an iPhone 12: paso 4, imagen 1 de 3 How to Replace a Screen Protector on an iPhone 12: paso 4, imagen 2 de 3 How to Replace a Screen Protector on an iPhone 12: paso 4, imagen 3 de 3
    • Grab the dust sticker and apply it all around on the screen multiple times, until you covered all areas of the iPhone display.
  5. How to Replace a Screen Protector on an iPhone 12: paso 5, imagen 1 de 3 How to Replace a Screen Protector on an iPhone 12: paso 5, imagen 2 de 3 How to Replace a Screen Protector on an iPhone 12: paso 5, imagen 3 de 3
    • Grab the screen protector and remove the plastic that's attached to the sticky part of the screen protector.
    • Align the new screen protector to the iPhone without touching the sticky part.
    • Press down on the screen protector from the top of the iPhone until you reach the bottom.
  6. How to Replace a Screen Protector on an iPhone 12: paso 6, imagen 1 de 3 How to Replace a Screen Protector on an iPhone 12: paso 6, imagen 2 de 3 How to Replace a Screen Protector on an iPhone 12: paso 6, imagen 3 de 3
    • With the new screen protector on the phone, use the anti-bubble card to prevent bubbles from staying in between the iPhone and the screen protector.
    • Push the bubbles towards the edge of the iPhone until you see no more on the screen.
  7. How to Replace a Screen Protector on an iPhone 12: paso 7, imagen 1 de 1
    • With the bubbles removed from the screen, the new screen protector for the iPhone 12 is now installed.
    • Dispose of any waste left after the installation.
Conclusión
reveleszacatecas5
Miembro Desde 10/24/23
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 53
Ultimos 30 días: 230
Todo El Tiempo: 1,351
