Saltar al contenido principal
How to Replace a Sash Window Lock
Qué necesitas
  1. How to Replace a Sash Window Lock, Window Lock: paso 1, imagen 1 de 2 How to Replace a Sash Window Lock, Window Lock: paso 1, imagen 2 de 2
    • Measure the length between the two screws on the lock.
    • Measure the width of the lock from the screw to the keeper.
    • These measurements help determine the size of lock you will need.
  2. How to Replace a Sash Window Lock: paso 2, imagen 1 de 3 How to Replace a Sash Window Lock: paso 2, imagen 2 de 3 How to Replace a Sash Window Lock: paso 2, imagen 3 de 3
    • Move the lock into a neutral position.
    • Remove the 12.7 mm screw on the left side of the lock with a Phillips #2 screwdriver.
  3. How to Replace a Sash Window Lock: paso 3, imagen 1 de 3 How to Replace a Sash Window Lock: paso 3, imagen 2 de 3 How to Replace a Sash Window Lock: paso 3, imagen 3 de 3
    • Remove the 12.7 mm Phillips #2 screw on the right side of the lock.
    • Remove the lock.
  4. How to Replace a Sash Window Lock: paso 4, imagen 1 de 3 How to Replace a Sash Window Lock: paso 4, imagen 2 de 3 How to Replace a Sash Window Lock: paso 4, imagen 3 de 3
    • Remove the left 12.7 mm screw on the lock keeper with a Phillips #2 screwdriver.
  5. How to Replace a Sash Window Lock: paso 5, imagen 1 de 2 How to Replace a Sash Window Lock: paso 5, imagen 2 de 2
    • Remove the right 12.7 mm Phillips #2 screw on the lock keeper.
    • The lock keeper will fall off of the window once the last screw is removed. Be ready to catch it!
  6. How to Replace a Sash Window Lock: paso 6, imagen 1 de 3 How to Replace a Sash Window Lock: paso 6, imagen 2 de 3 How to Replace a Sash Window Lock: paso 6, imagen 3 de 3
    • Line up the new lock keeper with the existing holes in the window.
    • Hold the keeper in place while inserting and tightening both the left and right 12.7 mm Phillips screws with a Phillips #2 screwdriver.
  7. How to Replace a Sash Window Lock: paso 7, imagen 1 de 3 How to Replace a Sash Window Lock: paso 7, imagen 2 de 3 How to Replace a Sash Window Lock: paso 7, imagen 3 de 3
    • Line up the new lock with the existing holes.
    • Hold the new lock in place while inserting and tightening the right 12.7 mm screw with a Phillips #2 screwdriver.
  8. How to Replace a Sash Window Lock: paso 8, imagen 1 de 3 How to Replace a Sash Window Lock: paso 8, imagen 2 de 3 How to Replace a Sash Window Lock: paso 8, imagen 3 de 3
    • Put the lock into a locked position.
    • Hold the new lock in place while inserting and tightening the left 12.7 mm Phillips #2 screw.
    • The new lock is now ready to be used!
Conclusión
Seb S
Miembro Desde 01/19/21
157 Reputación
1 Guía escrita
Un comentario
This replacement of sash hardware information is really fantastic, know I want to say that it's really appreciated, We also are providing builder hardware if you want in bulk. You can contact us
BuilderHardwarwe - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 110
Todo El Tiempo: 2,912
