Saltar al contenido principal
How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement
  1. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement, Receiver Wire: paso 1, imagen 1 de 1
    • This is the Widex Evoke 440 Hearing Aid that we will be replacing the receiver wire on. Colors may vary.
  2. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 2, imagen 1 de 1
    • Look for the exact part number you need, which is on the end of your Receiver.
    • The first letter corresponds to the strength of the receiver. It will be S for small, M for medium, or P for power.
    • The number corresponds to the length of the wire.
    • The next letter corresponds to which side the receiver is for, so it will be either L or R for left or right.
  3. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 3, imagen 1 de 2 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 3, imagen 2 de 2
    • Remove the battery from your hearing aid.
  4. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 4, imagen 1 de 3 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 4, imagen 2 de 3 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 4, imagen 3 de 3
    • Put your index finger under the curve in the wire near the base of the receiver.
    • Put your thumb over the receiver wire and grasp it tightly.
    • Pull the wire straight up out of the hearing aid.
  5. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 5, imagen 1 de 1
    • Your new hearing aid receiver wire will look like this out of the box.
  6. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 6, imagen 1 de 2 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 6, imagen 2 de 2
    • Slide the small plug at the end of the receiver into the hearing aid.
    • Push it all the way into the hearing aid by pushing down on the edge of the plug with your fingernail.
  7. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 7, imagen 1 de 2 How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 7, imagen 2 de 2
    • Put your silicone dome back on the receiver by lining it up with the receiver wire and pressing gently.
  8. How to Replace a Receiver Wire on a Widex Evoke 440 Hearing Aid Replacement: paso 8, imagen 1 de 1
    • Put your battery back in.
Linea de Meta
Tish Alexander
Miembro Desde 09/18/23
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 67
Todo El Tiempo: 375
