Saltar al contenido principal
How to Replace a Curtain Rod
Qué necesitas
  1. How to Replace a Curtain Rod, Curtain Rod: paso 1, imagen 1 de 2 How to Replace a Curtain Rod, Curtain Rod: paso 1, imagen 2 de 2
    • Remove the rod off the hook from the wall carefully with your hands.
  2. How to Replace a Curtain Rod: paso 2, imagen 1 de 3 How to Replace a Curtain Rod: paso 2, imagen 2 de 3 How to Replace a Curtain Rod: paso 2, imagen 3 de 3
    • Remove the screws from the hooks using a Phillips screwdriver or power drill with a Phillips head.
  3. How to Replace a Curtain Rod: paso 3, imagen 1 de 2 How to Replace a Curtain Rod: paso 3, imagen 2 de 2
    • Use the tape measure to determine screw placement on the wall for the new curtain rod.
  4. How to Replace a Curtain Rod: paso 4, imagen 1 de 2 How to Replace a Curtain Rod: paso 4, imagen 2 de 2
    • Replace the Phillips head in the power drill with a drill bit.
    • Drill the holes into the wall for the screws to secure firmly.
  5. How to Replace a Curtain Rod: paso 5, imagen 1 de 1
    • Place the screw into the hole on the hook and drill it into the holes on the wall.
  6. How to Replace a Curtain Rod: paso 6, imagen 1 de 2 How to Replace a Curtain Rod: paso 6, imagen 2 de 2
    • Measure an equal distance between each hook. Repeat Step 5 for drilling in each hook on the wall.
  7. How to Replace a Curtain Rod: paso 7, imagen 1 de 2 How to Replace a Curtain Rod: paso 7, imagen 2 de 2
    • Insert the rod into the curtain hole, leaving at least two inches of the rod on each side uncovered for hook placement.
  8. How to Replace a Curtain Rod: paso 8, imagen 1 de 2 How to Replace a Curtain Rod: paso 8, imagen 2 de 2
    • Place the rod onto the curve of the hook for attachment. Then straighten out the curtain across the window.
Linea de Meta
Andrew Pfeiffer
Miembro Desde 02/22/21
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 45
Todo El Tiempo: 1,136
