Introducción
Need to remove or replace an old cabinet door? Here's an easy step by step guide on removing and replacing a cabinet door using only a screwdriver.
Qué necesitas
Using a screwdriver, either a Flathead or a Phillips, remove the screws starting from the bottom of the door all the way to the top of the door to prevent the door from swinging.
To reassemble your cabinet, follow these instructions in reverse order.
Una persona más ha completado esta guía.
