Saltar al contenido principal
How to Replace a Bicycle Bell Disc
Qué necesitas
  1. How to Replace a Bicycle Bell Disc, Disc Bell: paso 1, imagen 1 de 2 How to Replace a Bicycle Bell Disc, Disc Bell: paso 1, imagen 2 de 2
    • Unscrew the exterior bell housing by rotating clockwise, then remove the housing.
  2. How to Replace a Bicycle Bell Disc: paso 2, imagen 1 de 2 How to Replace a Bicycle Bell Disc: paso 2, imagen 2 de 2
    • Rotate the parallel bars clockwise until they separate from the rod they're mounted on.
  3. How to Replace a Bicycle Bell Disc: paso 3, imagen 1 de 2 How to Replace a Bicycle Bell Disc: paso 3, imagen 2 de 2
    • Remove the rubber discs.
    • Grab your new rubber discs and insert one at each end of the parallel bars.
    • Make sure center of the rubber discs are held in place by the pins.
  4. How to Replace a Bicycle Bell Disc: paso 4, imagen 1 de 1
    • Test and rotate the discs with your finger to see if it is the appropriate size.
    • If the disc does not rotate easily, change the size of your metal disc to a narrower one.
  5. How to Replace a Bicycle Bell Disc: paso 5, imagen 1 de 2 How to Replace a Bicycle Bell Disc: paso 5, imagen 2 de 2
    • Rotate the parallel bars counterclockwise, into their original position.
  6. How to Replace a Bicycle Bell Disc: paso 6, imagen 1 de 2 How to Replace a Bicycle Bell Disc: paso 6, imagen 2 de 2
    • Replace the exterior housing and rotate it counterclockwise until it's fully secure.
Conclusión
Your bell should now be ringing like new!
Susan
Miembro Desde 01/19/22
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 75
Todo El Tiempo: 588
