Saltar al contenido principal
How to Replace a 2009-2015 Toyota Venza Brake Light
Qué necesitas
  1. How to Replace a 2009-2015 Toyota Venza Brake Light, Incandescent Brake Light: paso 1, imagen 1 de 1
    • Turn the car completely off and wait 30 minutes to ensure that the bulb is not hot.
    • If the car has not been on recently, then skip this step.
  2. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 2, imagen 1 de 2 How to Replace a 2009-2015 Toyota Venza Brake Light: paso 2, imagen 2 de 2
    • Open the back trunk.
  3. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 3, imagen 1 de 3 How to Replace a 2009-2015 Toyota Venza Brake Light: paso 3, imagen 2 de 3 How to Replace a 2009-2015 Toyota Venza Brake Light: paso 3, imagen 3 de 3
    • Use a flathead screwdriver to remove the vent located on the inside wall of the trunk.
  4. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 4, imagen 1 de 2 How to Replace a 2009-2015 Toyota Venza Brake Light: paso 4, imagen 2 de 2
    • Carefully reach your arm into the vent and locate the back of the socket.
    • Turn the socket counterclockwise to loosen it.
    • When loose, pull it out into view.
    • The brake bulb socket will be towards the top of the vent.
    • Ensure that bulb has had at least 30 minutes to cool. Touching the bulb while it is hot could result in burns.
  5. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 5, imagen 1 de 2 How to Replace a 2009-2015 Toyota Venza Brake Light: paso 5, imagen 2 de 2
    • Gently pull on the base of the bulb to loosen it from the socket.
    • When loose, remove the bulb from the socket.
  6. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 6, imagen 1 de 1
    • Carefully discard of the old bulb, and acquire the new bulb.
    • Wearing latex gloves when handling the new bulb(s) is highly recommended.
  7. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 7, imagen 1 de 1
    • Add bulb grease to the base of the new bulb.
  8. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 8, imagen 1 de 1
    • Return bulb to the socket by gently pushing the base of bulb into the empty socket until it clicks in.
  9. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 9, imagen 1 de 1
    • Reach your arm into the vent and locate the socket’s hole.
    • Replace the bulb and socket by screwing clockwise to tighten it.
  10. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 10, imagen 1 de 2 How to Replace a 2009-2015 Toyota Venza Brake Light: paso 10, imagen 2 de 2
    • Replace the vent into the wall of the trunk.
    • You will know that the vent is properly closed when it “pops” into place.
  11. How to Replace a 2009-2015 Toyota Venza Brake Light: paso 11, imagen 1 de 1
    • To test your new brake light, have an individual stand behind your car while you press on the brake. The light should come on when the brake is pressed.
    • Enjoy the new lights!
Conclusión
To replace your brake light on the other side, follow these same instructions. Otherwise, safe travels!
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 19
Ultimos 30 días: 84
Todo El Tiempo: 1,415
