Saltar al contenido principal
How to Replace Sequins or Beads
Qué necesitas
  1. How to Replace Sequins or Beads, How to Replace Sequins or Beads: paso 1, imagen 1 de 1
    • Gather the missing sequin, a needle, and thread. Put the thread through the needle.
  2. How to Replace Sequins or Beads: paso 2, imagen 1 de 1
    • Double knot both ends of the thread.
  3. How to Replace Sequins or Beads: paso 3, imagen 1 de 3 How to Replace Sequins or Beads: paso 3, imagen 2 de 3 How to Replace Sequins or Beads: paso 3, imagen 3 de 3
    • Make an anchor stitch where the missing item needs to be.
  4. How to Replace Sequins or Beads: paso 4, imagen 1 de 2 How to Replace Sequins or Beads: paso 4, imagen 2 de 2
    • Put the missing sequin or bead through the thread.
  5. How to Replace Sequins or Beads: paso 5, imagen 1 de 1
    • Slide the sequin or bead down the thread to the anchor stitch.
  6. How to Replace Sequins or Beads: paso 6, imagen 1 de 1
    • Make a straight stitch over one side of the sequin or bead into the fabric.
  7. How to Replace Sequins or Beads: paso 7, imagen 1 de 1
    • Put the needle through the back of the last stitch without puncturing the fabric.
  8. How to Replace Sequins or Beads: paso 8, imagen 1 de 1
    • Pull the thread through enough to make a circle.
  9. How to Replace Sequins or Beads: paso 9, imagen 1 de 2 How to Replace Sequins or Beads: paso 9, imagen 2 de 2
    • Pull the thread through the circle to make a knot.
Conclusión
Repeat the procedure for all missing sequins/beads/buttons on the clothing.
Garrett Wartelle
Miembro Desde 10/25/21
169 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 29
Todo El Tiempo: 1,200
