Saltar al contenido principal
How to Replace Magliner Hand Truck Wheels
Qué necesitas
  1. How to Replace Magliner Hand Truck Wheels, Replacement of Magliner Hand Truck Wheel: paso 1, imagen 1 de 3 How to Replace Magliner Hand Truck Wheels, Replacement of Magliner Hand Truck Wheel: paso 1, imagen 2 de 3 How to Replace Magliner Hand Truck Wheels, Replacement of Magliner Hand Truck Wheel: paso 1, imagen 3 de 3
    • Straighten the bottom of the cotter pin with the pliers to slide out the cotter pin.
  2. How to Replace Magliner Hand Truck Wheels: paso 2, imagen 1 de 2 How to Replace Magliner Hand Truck Wheels: paso 2, imagen 2 de 2
    • Remove the stainless steel washer(s) before pulling out the wheel(s) from the spindle.
  3. How to Replace Magliner Hand Truck Wheels: paso 3, imagen 1 de 2 How to Replace Magliner Hand Truck Wheels: paso 3, imagen 2 de 2
    • Pull the wheel in the opposite direction and slide out the old wheel(s).
  4. How to Replace Magliner Hand Truck Wheels: paso 4, imagen 1 de 3 How to Replace Magliner Hand Truck Wheels: paso 4, imagen 2 de 3 How to Replace Magliner Hand Truck Wheels: paso 4, imagen 3 de 3
    • Insert the new wheel into the wheel spindle.
    • There should be about half an inch left of the wheel spindle.
  5. How to Replace Magliner Hand Truck Wheels: paso 5, imagen 1 de 3 How to Replace Magliner Hand Truck Wheels: paso 5, imagen 2 de 3 How to Replace Magliner Hand Truck Wheels: paso 5, imagen 3 de 3
    • Replace the old washer(s) and add a new washer(s) on top of the wheel.
  6. How to Replace Magliner Hand Truck Wheels: paso 6, imagen 1 de 3 How to Replace Magliner Hand Truck Wheels: paso 6, imagen 2 de 3 How to Replace Magliner Hand Truck Wheels: paso 6, imagen 3 de 3
    • Replace the old cotter pin with a new cotter pin and slide it back into the hole at the edge of the wheel spindle.
  7. How to Replace Magliner Hand Truck Wheels: paso 7, imagen 1 de 3 How to Replace Magliner Hand Truck Wheels: paso 7, imagen 2 de 3 How to Replace Magliner Hand Truck Wheels: paso 7, imagen 3 de 3
    • Spread the right end of the new cotter pin(s) slightly outwards with the pliers.
    • This will create almost an L shape and secure the cotter pin in place.
Conclusión
Melissa Gaspar
Miembro Desde 03/25/24
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 197
