Saltar al contenido principal
How to Replace Keys on a Keyboard
Qué necesitas
  1. How to Replace Keys on a Keyboard, Individual Keys: paso 1, imagen 1 de 2 How to Replace Keys on a Keyboard, Individual Keys: paso 1, imagen 2 de 2
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: paso 2, imagen 1 de 2 How to Replace Keys on a Keyboard: paso 2, imagen 2 de 2
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: paso 4, imagen 1 de 1
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: paso 5, imagen 1 de 2 How to Replace Keys on a Keyboard: paso 5, imagen 2 de 2
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
Conclusión
Congratulations! You now have a keyboard with fully functional keys!
7 personas más completaron esta guía.
Cooper
Miembro Desde 02/24/15
493 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-6, Green Winter 2015 Miembro de Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
Miembros de 4
16 Guías creadas
2Guía Comentarios
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Contestar
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 40
Ultimos 30 días: 177
Todo El Tiempo: 20,031
