Saltar al contenido principal
How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method
  1. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method, Shoelace: paso 1, imagen 1 de 1
    • Starting with the top eyelets on the right shoe, remove the first two sides of the lace on both sides.
  2. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 2, imagen 1 de 1
    • Continue removing the lace from each side’s eyelets until the shoe reaches the last eyelet set.
  3. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 3, imagen 1 de 1
    • Remove the entire lace through either the right or left outlet.
  4. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 4, imagen 1 de 1
    • Set aside old lace to be recycled or cleaned.
  5. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 5, imagen 1 de 1
    • Repeat Steps 1-4 with the left shoe.
  6. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 6, imagen 1 de 1
    • Push the lip of the right shoe downward, so it is flush with the insole.
    • Obtain one new lace.
  7. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 8, imagen 1 de 1
    • Find the approximate center of the lace and pinch it between your right index finger and thumb.
  8. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 9, imagen 1 de 1
    • Starting from inside the right shoe, place the center of the lace between the center of the top eyelets.
  9. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 10, imagen 1 de 1
    • Pull the left end of the lace through the top left eyelet.
  10. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 11, imagen 1 de 1
    • Pull the right end of the lace through the top right eyelet.
  11. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 12, imagen 1 de 1
    • Leave an approx. 4" loop of slack lace at each side of the top eyelets, starting with the left side.
  12. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 13, imagen 1 de 1
    • Form the right 4" loop.
  13. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 14, imagen 1 de 1
    • Tie a Starting Knot after securing the 4" loops with clips. Start by crossing the left lace over the right.
  14. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 15, imagen 1 de 1
    • Wrap the right lace around the front of the left lace, the right lace should end up at the back of the gap between laces.
  15. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 16, imagen 1 de 1
    • Pull the right lace through the gap towards the front.
  16. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 17, imagen 1 de 1
    • Pull both ends of the lace to tighten, without removing the 4” loops.
  17. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 18, imagen 1 de 1
    • Pull the lace coming from the left side of the Starting Knot through the second left eyelet towards the inside of the shoe, without removing the 4” loop.
  18. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 19, imagen 1 de 1
    • Pull the lace coming from the right side of the Starting Knot through the second right eyelet towards the inside of the shoe, without removing the 4” loop.
    • Pull the rightmost lace end across the shoe from the right second eyelet diagonally to the left third eyelet.
    • Pull the leftmost lace end across the shoe from the left second eyelet diagonally to the right third eyelet.
    • Pull both lace ends through the top of the third eyelets.
  19. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 23, imagen 1 de 1
    • Repeat steps 16-18 until the last two eyelets are reached.
  20. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 24, imagen 1 de 1
    • Tie two Stopper Knots on both ends of the lace at the last eyelets. Start by grabbing the right lace end and forming a small loop.
  21. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 25, imagen 1 de 1
    • Bring the lace end through the back of the loop.
  22. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 26, imagen 1 de 1
    • Tighten by pulling on the end of the lace.
  23. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 27, imagen 1 de 1
    • Repeat the Stopper Knot steps with the left lace end.
  24. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 28, imagen 1 de 1
    • Tuck the Stopper Knots over the lip and under the eyelets.
    • Ensure the end of the lace is also tucked underneath the eyelets.
  25. How to Replace High-Top Sneakers' Shoelaces Using the Ukrainian Method: paso 29, imagen 1 de 1
    • Take out the clips holding the top two 4" loops and tie the shoe regularly.
Conclusión
To reassemble your sneaker, follow these instructions in reverse order.
2 personas más completaron esta guía.
Un comentario
Dear ifixit,
This post worked great.
This post has really helped my visitors. Your "less writing and more picture" structure has helped my visitors to understand. Anyone who wants to lace shoes perfectly should really read this article. Thank you ..
In fact, I have posted a article about shoelaces ( read this ). On this post i've tried to provide valuable information about different types of shoelaces and their features. Hope you'll like it.
Shoes lo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 18
Todo El Tiempo: 1,165
