Introducción
Use this guide to replace the broken glass on any picture frame.
Whether the glass broke while moving or someone knocked it off a shelf, you can replace glass in a variety of ways. This guide will cover the process of cutting the glass yourself.
Glass can help protect your photos from humidity, heat, and overall cleanliness. Some glass can help with glares or protect from ultraviolet rays.
This guide will have sharp edges from the glass you will be cutting. Ensure you take the proper safety precautions throughout this guide.
Qué necesitas
Undo the fasteners holding the back onto the frame.
Grab the backing to pull it away from the frame.
Align the cutting mat along the marks you made on the glass.
Place the china marker on one edge of the glass, and use the cutting mat to help create a line going to the other end.
Place the blade of the glass cutter on the edge of the glass, and follow the same path you created with the china marker to score the glass.
Herramienta utilizada en este paso:Microfiber Cleaning Cloths$3.99
Apply rubbing alcohol to a microfiber cloth.
Rub the edges of your glass carefully to remove any marks you created.
To reassemble your picture frame, follow step one in reverse order.
