Saltar al contenido principal
How to Replace Blu Studio Selfie Microphone
Qué necesitas
  1. How to Replace Blu Studio Selfie Microphone, Rear Cover: paso 1, imagen 1 de 1
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. How to Replace Blu Studio Selfie Microphone: paso 2, imagen 1 de 1
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. How to Replace Blu Studio Selfie Microphone, Battery: paso 3, imagen 1 de 2 How to Replace Blu Studio Selfie Microphone, Battery: paso 3, imagen 2 de 2
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
  4. How to Replace Blu Studio Selfie Microphone, Midframe: paso 4, imagen 1 de 1
    • Remove all the 4mm Phillips #000 screws from the midframe.
  5. How to Replace Blu Studio Selfie Microphone: paso 5, imagen 1 de 1
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. How to Replace Blu Studio Selfie Microphone: paso 6, imagen 1 de 1
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
  7. How to Replace Blu Studio Selfie Microphone, Microphone: paso 7, imagen 1 de 2 How to Replace Blu Studio Selfie Microphone, Microphone: paso 7, imagen 2 de 2
    • Remove three 4 mm Phillips #000 screws holding the motherboard in place.
    • Carefully lift the motherboard from the phone, exposing the microphone soldering connections.
  8. How to Replace Blu Studio Selfie Microphone: paso 8, imagen 1 de 2 How to Replace Blu Studio Selfie Microphone: paso 8, imagen 2 de 2
    • Use a soldering iron to desolder the microphone from the phone.
    • Learn more about soldering here.
Conclusión
2 personas más completaron esta guía.
Stacy Kam
Miembro Desde 01/20/16
630 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 10-1, Remmell Spring 2016 Miembro de USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 433
