Saltar al contenido principal
How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers
Qué necesitas
  1. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers, Windshield Wipers: paso 1, imagen 1 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers, Windshield Wipers: paso 1, imagen 2 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers, Windshield Wipers: paso 1, imagen 3 de 3
    • Go inside your car and press the “CAR” button on the control panel.
    • Scroll down using the control wheel to "Windshield wipers".
    • Press the center button on the control wheel to select the option.
  2. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 2, imagen 1 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 2, imagen 2 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 2, imagen 3 de 3
    • Press the center button on the control wheel to edit the service position.
    • In the drop-down menu, switch it from "off" to "on" by scrolling with the control wheel and pressing the center button.
    • The windshield wipers will now be in the up position.
  3. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 3, imagen 1 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 3, imagen 2 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 3, imagen 3 de 3
    • You should be able to lift the windshield wipers towards the windshield at 90 degrees.
    • Lift the windshield blades to about 120 degrees.
  4. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 4, imagen 1 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 4, imagen 2 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 4, imagen 3 de 3
    • In the packaging for the Michelin windshield wipers, the wipers are pre-installed with a top-lock connector.
    • Raise the pre-installed top-lock connector.
  5. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 5, imagen 1 de 2 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 5, imagen 2 de 2
    • Pinch the bottom of the connector to release the cover and remove the top-lock connector.
    • The Audi A4 uses a “Top Lock-Narrow” connector.
  6. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 6, imagen 1 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 6, imagen 2 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 6, imagen 3 de 3
    • Install the new "Top Lock-Narrow" connector onto the base connector.
    • Press down until it clicks into place.
  7. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 7, imagen 1 de 2 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 7, imagen 2 de 2
    • Install the blade into the blade arm, sliding the new wiper blades down until it clicks and is locked into place.
    • Make sure to install the 24 inches wiper blade on the driver side, and the 20 inches wiper blade on the passenger side.
  8. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 8, imagen 1 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 8, imagen 2 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 8, imagen 3 de 3
    • Install the new connector cover by pinching the base of the connector.
    • Close the connector cover on both sides of the wiper blades.
  9. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 9, imagen 1 de 2 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 9, imagen 2 de 2
    • Remove the yellow wiper protector on both blades.
    • Put the wiper back on the windshield
  10. How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 10, imagen 1 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 10, imagen 2 de 3 How to Replace 2009-2016 Audi A4 (B8) Windshield Wipers: paso 10, imagen 3 de 3
    • Set the windshield wiper service position back to "off".
Conclusión
Test the new wiper blades before you hit the road for safety.
Una persona más ha completado esta guía.
Vinod Ragoonauth
Miembro Desde 09/25/22
190 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 119
Todo El Tiempo: 2,421
