Saltar al contenido principal
How to Repair the Sparker on a Merlion Mini Torch
Qué necesitas
  1. How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: paso 1, imagen 1 de 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: paso 1, imagen 2 de 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: paso 1, imagen 3 de 3
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. How to Repair the Sparker on a Merlion Mini Torch: paso 2, imagen 1 de 2 How to Repair the Sparker on a Merlion Mini Torch: paso 2, imagen 2 de 2
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. How to Repair the Sparker on a Merlion Mini Torch: paso 3, imagen 1 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 3, imagen 2 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 3, imagen 3 de 3
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. How to Repair the Sparker on a Merlion Mini Torch: paso 4, imagen 1 de 2 How to Repair the Sparker on a Merlion Mini Torch: paso 4, imagen 2 de 2
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. How to Repair the Sparker on a Merlion Mini Torch: paso 5, imagen 1 de 2 How to Repair the Sparker on a Merlion Mini Torch: paso 5, imagen 2 de 2
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. How to Repair the Sparker on a Merlion Mini Torch: paso 6, imagen 1 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 6, imagen 2 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 6, imagen 3 de 3
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. How to Repair the Sparker on a Merlion Mini Torch: paso 7, imagen 1 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 7, imagen 2 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 7, imagen 3 de 3
    • Take the empty half of the torch and place it over the other half.
  8. How to Repair the Sparker on a Merlion Mini Torch: paso 8, imagen 1 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 8, imagen 2 de 3 How to Repair the Sparker on a Merlion Mini Torch: paso 8, imagen 3 de 3
    • Use the screwdriver to put the screws back in the torch.
  9. How to Repair the Sparker on a Merlion Mini Torch: paso 9, imagen 1 de 2 How to Repair the Sparker on a Merlion Mini Torch: paso 9, imagen 2 de 2
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
Conclusión
Congrats! Now you can use your Merlion torch again.
3 personas más completaron esta guía.
Neel Kogali
Miembro Desde 09/29/15
200 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 14-3, Green Fall 2015 Miembro de Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 21
Todo El Tiempo: 7,555
