Saltar al contenido principal
How to Repair the Lining of a Leather Wallet
Qué necesitas
  1. How to Repair the Lining of a Leather Wallet, Lining: paso 1, imagen 1 de 1
    • Use scissors to cut any hanging threads.
  2. How to Repair the Lining of a Leather Wallet: paso 2, imagen 1 de 2 How to Repair the Lining of a Leather Wallet: paso 2, imagen 2 de 2
    • Flip the entire wallet inside out.
  3. How to Repair the Lining of a Leather Wallet: paso 3, imagen 1 de 3 How to Repair the Lining of a Leather Wallet: paso 3, imagen 2 de 3 How to Repair the Lining of a Leather Wallet: paso 3, imagen 3 de 3
    • Pin the cloth into place with safety pins.
    • Make sure not to poke through the leather. If there is no way to do this without damaging the leather, skip this step.
  4. How to Repair the Lining of a Leather Wallet: paso 4, imagen 1 de 2 How to Repair the Lining of a Leather Wallet: paso 4, imagen 2 de 2
    • Cut about a centimeter off the end of the sewing thread to get rid of any fraying.
    • Guide the thread through the hole at the top of the needle.
    • Pull about 20.32-30.48 cm of the thread through to prevent the thread from slipping out while sewing.
    • If it is too difficult to get the thread through the hole, wet the end of the thread and roll it between two fingers to create a pointed end and try again.
    • Cut about 0.91 meters of thread from the spool.
  5. How to Repair the Lining of a Leather Wallet: paso 5, imagen 1 de 3 How to Repair the Lining of a Leather Wallet: paso 5, imagen 2 de 3 How to Repair the Lining of a Leather Wallet: paso 5, imagen 3 de 3
    • Starting at the beginning of the tear, sew thread from the inside of the wallet to the outside.
    • Sew thread back from the outside of the wallet to the inside of the wallet.
    • Tie the threads together 2 or 3 times.
    • Leave very little gap between first and second stitch hole.
  6. How to Repair the Lining of a Leather Wallet: paso 6, imagen 1 de 2 How to Repair the Lining of a Leather Wallet: paso 6, imagen 2 de 2
    • Locate holes in the leather from existing stitches and sew through them, making sure to avoid damaging it.
    • Perform a standard backstitch: skip one of the holes and sew from the inside of the wallet to the outside through second hole, then sew from the outside to the inside through the hole that was skipped.
    • Repeat until the lining is completely reattached.
  7. How to Repair the Lining of a Leather Wallet: paso 7, imagen 1 de 2 How to Repair the Lining of a Leather Wallet: paso 7, imagen 2 de 2
    • At the end of the tear, sew from the inside of the wallet to the outside, leaving a sizable loop of thread.
    • Sew thread back from the outside of the wallet to the inside, leaving very little space between stitches.
  8. How to Repair the Lining of a Leather Wallet: paso 8, imagen 1 de 2 How to Repair the Lining of a Leather Wallet: paso 8, imagen 2 de 2
    • Tie the loop and the hanging thread together 2 or 3 times.
  9. How to Repair the Lining of a Leather Wallet: paso 9, imagen 1 de 2 How to Repair the Lining of a Leather Wallet: paso 9, imagen 2 de 2
    • Cut any extra thread and remove the safety pins.
  10. How to Repair the Lining of a Leather Wallet: paso 10, imagen 1 de 2 How to Repair the Lining of a Leather Wallet: paso 10, imagen 2 de 2
    • Flip the wallet back so the lining is on the inside.
    • The lining should be securely attached to the interior of the wallet!
Linea de Meta
Riya
Miembro Desde 01/26/23
181 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-6, Morris Winter 2023 Miembro de UC Davis, Team 2-6, Morris Winter 2023
UCD-MORRIS-W23S2G6
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 87
Todo El Tiempo: 992
