Saltar al contenido principal
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
Qué necesitas
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 1, imagen 1 de 1
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 2, imagen 1 de 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 2, imagen 2 de 2
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 3, imagen 1 de 1
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 4, imagen 1 de 1
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 5, imagen 1 de 1
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 6, imagen 1 de 1
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 7, imagen 1 de 1
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 8, imagen 1 de 2 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 8, imagen 2 de 2
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 9, imagen 1 de 1
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 10, imagen 1 de 1
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 11, imagen 1 de 1
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 12, imagen 1 de 1
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: paso 13, imagen 1 de 1
    • You are now finished!
Linea de Meta
John Hiller
Miembro Desde 10/05/15
110 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,841
