Saltar al contenido principal
How to Repair the Buttons on a Logitech Pebble Mouse
Qué necesitas
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: paso 1, imagen 1 de 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: paso 1, imagen 2 de 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: paso 1, imagen 3 de 3
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: paso 2, imagen 1 de 3 How to Repair the Buttons on a Logitech Pebble Mouse: paso 2, imagen 2 de 3 How to Repair the Buttons on a Logitech Pebble Mouse: paso 2, imagen 3 de 3
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: paso 3, imagen 1 de 2 How to Repair the Buttons on a Logitech Pebble Mouse: paso 3, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: paso 4, imagen 1 de 3 How to Repair the Buttons on a Logitech Pebble Mouse: paso 4, imagen 2 de 3 How to Repair the Buttons on a Logitech Pebble Mouse: paso 4, imagen 3 de 3
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: paso 5, imagen 1 de 1
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: paso 6, imagen 1 de 3 How to Repair the Buttons on a Logitech Pebble Mouse: paso 6, imagen 2 de 3 How to Repair the Buttons on a Logitech Pebble Mouse: paso 6, imagen 3 de 3
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
Conclusión
Una persona más ha completado esta guía.
Emma Whitmer
Miembro Desde 04/19/23
151 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-6, Morris Spring 2023 Miembro de UC Davis, Team 2-6, Morris Spring 2023
UCD-MORRIS-S23S2G6
3 Miembros
1 Guía escrita
2 comentarios
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - Contestar
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 131
Todo El Tiempo: 1,787
