Saltar al contenido principal
How to Repair the Broken End of a Garden Hose
Qué necesitas
  1. How to Repair the Broken End of a Garden Hose, How to Repair the Broken End of a Garden Hose: paso 1, imagen 1 de 1
    • Measure the diameter of the inside of the original hose.
  2. How to Repair the Broken End of a Garden Hose: paso 2, imagen 1 de 1
    • Choose the right size of the hose end.
    • Know the difference between the male and female ends (the featured end is female).
    • Hoses typically come in sizes 5/8", 3/4", and 1/2".
  3. How to Repair the Broken End of a Garden Hose: paso 3, imagen 1 de 1
    • Remove the original broken end by using a utility knife to cut 2-3 inches from the hose.
    • Place the hose on a flat surface such as a workbench, and perform a smooth, straight cut.
  4. How to Repair the Broken End of a Garden Hose: paso 4, imagen 1 de 1
    • Remove the fitting.
  5. How to Repair the Broken End of a Garden Hose: paso 5, imagen 1 de 3 How to Repair the Broken End of a Garden Hose: paso 5, imagen 2 de 3 How to Repair the Broken End of a Garden Hose: paso 5, imagen 3 de 3
    • Attach the new fitting.
    • Slide the clamp onto the hose.
    • Insert the new fitting.
    • Soak the hose in warm water or let it sit in the sun to make it more pliable.
  6. How to Repair the Broken End of a Garden Hose: paso 6, imagen 1 de 1
    • Tighten the clamp with a screwdriver.
Conclusión
Test your new and improved hose by turning on the water and watching for leaks.
3 personas más completaron esta guía.
Un comentario
Warm water is a good idea.
pwkoughan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 40
Ultimos 30 días: 117
Todo El Tiempo: 6,039
