Saltar al contenido principal
How to Repair an Unstable Sliding Door
Qué necesitas
  1. How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: paso 1, imagen 1 de 3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: paso 1, imagen 2 de 3 How to Repair an Unstable Sliding Door, How to Repair an Unstable Sliding Door: paso 1, imagen 3 de 3
    • Investigate the cause of the unstable sliding door.
    • In this case you can see the sliding tract isn't aligned with the bottom roller.
    • You can also see that the screw at the base has been dislodged.
  2. How to Repair an Unstable Sliding Door: paso 2, imagen 1 de 3 How to Repair an Unstable Sliding Door: paso 2, imagen 2 de 3 How to Repair an Unstable Sliding Door: paso 2, imagen 3 de 3
    • Remove the screws used to hold the door in place with a Phillips screwdriver.
    • Once the doors are loose from the tracks, remove them.
  3. How to Repair an Unstable Sliding Door: paso 3, imagen 1 de 3 How to Repair an Unstable Sliding Door: paso 3, imagen 2 de 3 How to Repair an Unstable Sliding Door: paso 3, imagen 3 de 3
    • Check to see that the rollers are securely in place.
    • If there are any bits of debris present on the rollers or the tracks, clean it off with isopropyl alcohol and a clean rag.
  4. How to Repair an Unstable Sliding Door: paso 4, imagen 1 de 3 How to Repair an Unstable Sliding Door: paso 4, imagen 2 de 3 How to Repair an Unstable Sliding Door: paso 4, imagen 3 de 3
    • Place the doors back on the rollers.
    • Replace the screws you removed earlier.
    • Check that the rollers move freely. You can test this by using your hands to roll them forward to your satisfaction.
  5. How to Repair an Unstable Sliding Door: paso 5, imagen 1 de 3 How to Repair an Unstable Sliding Door: paso 5, imagen 2 de 3 How to Repair an Unstable Sliding Door: paso 5, imagen 3 de 3
    • Align the door on both tracks.
    • Start by attaching the head of the door first and then lower body into the track. Avoid forcing into the track as this might damage the rollers.
    • Make sure that it is aligned properly so it does not fall out in the future.
Linea de Meta
Barabonye Longjohn
Miembro Desde 09/21/20
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 348
