Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair a Warped Cooking Pan
Qué necesitas
    1. How to Repair a Warped Cooking Pan, How to Repair a Warped Cooking Pan: paso 1, imagen 1 de 1
      • Locate the hard surface you will use for the repair.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair a Warped Cooking Pan: paso 2, imagen 1 de 1
      • Place one of the two towels on top of the hard surface.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair a Warped Cooking Pan: paso 3, imagen 1 de 1
      • Turn on the stove to medium heat to warm up the bottom of the cooking pan that is warped.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair a Warped Cooking Pan: paso 4, imagen 1 de 1
      • As soon as the pan is warm or hot to the touch, quickly remove it from the stove.
      • Turn off the stove and place the pan, bottom up, on top of the towel that is placed on the hard surface.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair a Warped Cooking Pan: paso 5, imagen 1 de 2 How to Repair a Warped Cooking Pan: paso 5, imagen 2 de 2
      • Place the second towel on top of the bottom of the pan that is facing upward.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair a Warped Cooking Pan: paso 6, imagen 1 de 1
      • Place the block of wood on top of the second towel that is placed on the pan.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Repair a Warped Cooking Pan: paso 7, imagen 1 de 2 How to Repair a Warped Cooking Pan: paso 7, imagen 2 de 2
      • Carefully hammer directly onto the block of wood.
      • Make sure that the block of wood is still firmly on top of the bottom of the pan. This will help ensure that the pan is repaired properly.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Repair a Warped Cooking Pan: paso 8, imagen 1 de 1
      • Your cooking pan should no longer be warped. You are finished!
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
angieaguirre
Miembro Desde 02/21/24
184 Reputación
1 Guía escrita
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 17
Ultimos 7 días: 77
Ultimos 30 días: 319
Todo El Tiempo: 2,311
