Saltar al contenido principal
How to Repair a Vintage Handheld 'Bricks' Video Game
Qué necesitas
  1. How to Repair a Vintage Handheld 'Bricks' Video Game, How to Repair a Vintage Handheld 'Bricks' Video Game: paso 1, imagen 1 de 2 How to Repair a Vintage Handheld 'Bricks' Video Game, How to Repair a Vintage Handheld 'Bricks' Video Game: paso 1, imagen 2 de 2
    • Use a Phillips 1 screwdriver to unfasten the four screws from the back of the case.
    • Remove the battery cover to expose the two remaining screws that hold the case together.
  2. How to Repair a Vintage Handheld 'Bricks' Video Game: paso 2, imagen 1 de 2 How to Repair a Vintage Handheld 'Bricks' Video Game: paso 2, imagen 2 de 2
    • Unfasten the last two screws, and open the case.
  3. How to Repair a Vintage Handheld 'Bricks' Video Game: paso 3, imagen 1 de 1
    • Identify the wire(s) which have been disconnected, and identify their original location.
    • If two or more wires were disconnected, use two AA batteries to verify the correct wiring. The game’s starting melody will be audible if the wiring is correct.
  4. How to Repair a Vintage Handheld 'Bricks' Video Game: paso 4, imagen 1 de 2 How to Repair a Vintage Handheld 'Bricks' Video Game: paso 4, imagen 2 de 2
    • Using the same Phillips 1 screwdriver, unfasten the two smaller screws holding the controller board to the case .
    • Remember the position of the screws; take a picture if need be.
  5. How to Repair a Vintage Handheld 'Bricks' Video Game: paso 5, imagen 1 de 3 How to Repair a Vintage Handheld 'Bricks' Video Game: paso 5, imagen 2 de 3 How to Repair a Vintage Handheld 'Bricks' Video Game: paso 5, imagen 3 de 3
    • Verify that the detached wire(s) reach the intended destination.
    • Use a blade or wire stripper to strip 0.5 cm of insulation off the end of the wire(s) to be soldered.
    • Sharp tool!
  6. How to Repair a Vintage Handheld 'Bricks' Video Game: paso 6, imagen 1 de 3 How to Repair a Vintage Handheld 'Bricks' Video Game: paso 6, imagen 2 de 3 How to Repair a Vintage Handheld 'Bricks' Video Game: paso 6, imagen 3 de 3
    • Re-solder the disconnected wire to the proper joint.
    • Lightly tug on the newly soldered wire to confirm a reliable solder joint.
    • Refer to Cómo soldar y desoldar conexiones if needed.
    • Hot iron! Noxious fumes!
  7. How to Repair a Vintage Handheld 'Bricks' Video Game: paso 7, imagen 1 de 1
    • Assembly is the reverse of disassembly.
    • Install two AA batteries, and verify audibility of the game prior to reassembly.
Conclusión
Although newly manufactured hand-held Brick gaming consoles are plentiful to purchase online, the owner of an earlier generation hand-held Brick gaming console will most likely want to keep the original ones they bought. There is no telling if/when these devices will become a collector's item, but history has shown that not all types and models of these hand-held Brick games are being manufactured. Some models were manufactured for a very limited period of time. The owners of those rare Brick games will eventually want to fix theirs. Not much else can go wrong with these Brick games as long as the owners protect the LCD screens from damage.
Nardeen Hamid
Miembro Desde 02/10/16
101 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 26
Todo El Tiempo: 3,353
