Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair a Towel Hem
Qué necesitas
    1. How to Repair a Towel Hem, How to Repair a Towel Hem: paso 1, imagen 1 de 2 How to Repair a Towel Hem, How to Repair a Towel Hem: paso 1, imagen 2 de 2
      • Use sewing scissors to cut a piece of thread twice the length of your arm.
      • Push one end of the thread through the hole at one end of the needle.
      • Hold both ends of the thread in your hands.
      • Make a knot at the very end of the thread.
      • Multiple knots will help to ensure that the thread does not come all the way through the fabric.
      • Needles can be very sharp. Pay attention to your fingers.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair a Towel Hem: paso 2, imagen 1 de 3 How to Repair a Towel Hem: paso 2, imagen 2 de 3 How to Repair a Towel Hem: paso 2, imagen 3 de 3
      • Snip the extra thread along the hem with scissors.
      • Take the top of the edge of the towel and fold the entire hem towards you.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair a Towel Hem: paso 3, imagen 1 de 1
      • Make sure that the folded hem is facing you for this step.
      • Be careful! These pins are very sharp.
      • Hold the ball of the pin and push it in from the front.
      • Push the end of the pin from behind back through the front.
      • With the very end of the pin poking out, push the tip into the towel to the left.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair a Towel Hem: paso 4, imagen 1 de 2 How to Repair a Towel Hem: paso 4, imagen 2 de 2
      • Make sure that the folded hem is facing you at the beginning of this step.
      • Insert your needle just to the left of the very thick edge, so it will pierce through the corner.
      • Pull the needle all of the way through and come back to the front.
      • Repeat this until you have gone front to back at least 5 times.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair a Towel Hem: paso 5, imagen 1 de 1
      • Working from front you back, insert your needle and pull it all of the way through.
      • Go about a half inch to the left and insert your needle back to the front.
      • Going another half inch to the left, repeat these steps and stitch evenly along the lower edge of the hem until you reach the end of the towel.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair a Towel Hem: paso 6, imagen 1 de 3 How to Repair a Towel Hem: paso 6, imagen 2 de 3 How to Repair a Towel Hem: paso 6, imagen 3 de 3
      • This step will assist you with starting a new piece of thread in the middle of your hem.
      • Hold both strands to make a knot close to the towel and trim the ends.
      • Knot your new thread and insert it close to your recent stitch, coming back through.
      • Put your needle under the line of thread you just recently stitched to the right, pulling your thread almost all of the way through.
      • Put your needle under the thread from your current stitch.
      • Like in the third picture, you will want to pull the loop at the top until you have a flat line across.
      • Pull your thread all of the way through to make it stay.
      • Go back through your initial hole towards the back, then come up through to the front on the other side of your current stitch.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Repair a Towel Hem: paso 7, imagen 1 de 2 How to Repair a Towel Hem: paso 7, imagen 2 de 2
      • You can start at the back or the front of this corner. It will depend on where you are from your stitches across the hem.
      • Insert your needle just to the right of the very thick edge.
      • Just like the first corner, you will go front to back (or back to front) 5 times.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Repair a Towel Hem: paso 8, imagen 1 de 2 How to Repair a Towel Hem: paso 8, imagen 2 de 2
      • It is okay to go over your previous stitches. A second layer of sewing will make this stronger.
      • Sew across the hem one more time back to the beginning.
      Pregunta a FixBot
      Agregar Comentario
    9. How to Repair a Towel Hem: paso 9, imagen 1 de 3 How to Repair a Towel Hem: paso 9, imagen 2 de 3 How to Repair a Towel Hem: paso 9, imagen 3 de 3
      • Once you reach the other edge, knot and trim your loose ends.
      • Give yourself a high five! Now you are done!
      Pregunta a FixBot
      Agregar Comentario
Conclusión
I am right-handed, which is how this guide was designed. The steps should still work, even if you are left-handed or decide to start with the left corner. Thank you for taking care of your towels!
4 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 75
Ultimos 30 días: 180
Todo El Tiempo: 1,568
