Saltar al contenido principal
How to Repair a Small Hole in Your Clothing
Qué necesitas
  1. How to Repair a Small Hole in Your Clothing, How to Repair a Small Hole in Your Clothing: paso 1, imagen 1 de 1
    • Grab the clothing you want to fix and lay it on a table.
  2. How to Repair a Small Hole in Your Clothing: paso 2, imagen 1 de 1
    • Find the thread that matches the colour of the clothing you are going to repair.
    • Measure and cut a piece of string a minimum of 20x the length of the hole.
  3. How to Repair a Small Hole in Your Clothing: paso 3, imagen 1 de 3 How to Repair a Small Hole in Your Clothing: paso 3, imagen 2 de 3 How to Repair a Small Hole in Your Clothing: paso 3, imagen 3 de 3
    • Insert the thread through the eye of the needle.
  4. How to Repair a Small Hole in Your Clothing: paso 4, imagen 1 de 3 How to Repair a Small Hole in Your Clothing: paso 4, imagen 2 de 3 How to Repair a Small Hole in Your Clothing: paso 4, imagen 3 de 3
    • Pull the thread through until the length of both ends of the thread are the same length.
    • Tie the ends in a double knot.
  5. How to Repair a Small Hole in Your Clothing: paso 5, imagen 1 de 3 How to Repair a Small Hole in Your Clothing: paso 5, imagen 2 de 3 How to Repair a Small Hole in Your Clothing: paso 5, imagen 3 de 3
    • Pinch the fabric to close the hole, and weave the needle back and forth through the pinch until the hole is sealed.
  6. How to Repair a Small Hole in Your Clothing: paso 6, imagen 1 de 2 How to Repair a Small Hole in Your Clothing: paso 6, imagen 2 de 2
    • Cut the thread from the needle and cut the leftover thread on both ends of the sealed hole.
  7. How to Repair a Small Hole in Your Clothing: paso 7, imagen 1 de 1
    • The hole is completely sealed!
Linea de Meta
Ann
Miembro Desde 09/19/20
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 41
Ultimos 30 días: 211
Todo El Tiempo: 4,829
