Saltar al contenido principal
How to Repair a Scratched CD
Qué necesitas
  1. How to Repair a Scratched CD, How to Repair a Scratched CD: paso 1, imagen 1 de 1
    • Rinse the disc with water and wipe clean to remove any dust or dirt.
  2. How to Repair a Scratched CD: paso 2, imagen 1 de 3 How to Repair a Scratched CD: paso 2, imagen 2 de 3 How to Repair a Scratched CD: paso 2, imagen 3 de 3
    • Apply a rubbing compound, moving from the center of the disc outwards.
    • Use enough force to create a mirror polished surface when rubbing compound application is complete.
    • We found that applying the rubbing compound for at least 30 seconds to 1 minute is sufficient.
  3. How to Repair a Scratched CD: paso 3, imagen 1 de 1
    • Let the CD sit for 5 minutes.
  4. How to Repair a Scratched CD: paso 4, imagen 1 de 2 How to Repair a Scratched CD: paso 4, imagen 2 de 2
    • Wipe the CD clean with a new rag, removing any excess compound.
  5. How to Repair a Scratched CD: paso 5, imagen 1 de 3 How to Repair a Scratched CD: paso 5, imagen 2 de 3 How to Repair a Scratched CD: paso 5, imagen 3 de 3
    • Apply a thin coat of car wax directly to the CD, using a circular application method.
    • Apply in either small circular motions or large motions that follow the circumference of the disc.
  6. How to Repair a Scratched CD: paso 6, imagen 1 de 2 How to Repair a Scratched CD: paso 6, imagen 2 de 2
    • Wipe the CD clean, removing any excess wax.
Conclusión
Congratulations! You have successfully repaired the scratched CD!
7 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 40
Ultimos 30 días: 176
Todo El Tiempo: 12,994
