Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair a Popped-Off Owala Cap and Carry Loop
Qué necesitas
    1. How to Repair a Popped-Off Owala Cap and Carry Loop, How to Repair a Popped-Off Owala Cap and Carry Loop: paso 1, imagen 1 de 1
      • Clean and dry your water bottle.
      • Keeping your parts dry and clean will help with precision.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair a Popped-Off Owala Cap and Carry Loop: paso 2, imagen 1 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 2, imagen 2 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 2, imagen 3 de 3
      • Notice the groove; this will assist with step 5.
      • Align the carry loop properly with the cap.
      • Be sure to align the loop so that the groove is facing upward.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair a Popped-Off Owala Cap and Carry Loop: paso 3, imagen 1 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 3, imagen 2 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 3, imagen 3 de 3
      • Slide the carry loop into the sockets on each side of the lid.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair a Popped-Off Owala Cap and Carry Loop: paso 4, imagen 1 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 4, imagen 2 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 4, imagen 3 de 3
      • Hook the wire onto the hinge of the lid.
      • Use the tweezers to secure the wire onto the hinges of the lid.
      • Push the hinge of the wire under the rubber in the lid to secure it.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair a Popped-Off Owala Cap and Carry Loop: paso 5, imagen 1 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 5, imagen 2 de 3 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 5, imagen 3 de 3
      • Identifying the holes on the lid beforehand is helpful here.
      • Grab the short length of the wire coil and stick it into the small hole on the lid.
      • Place the first side of the wire into the small hole on the side of the lid that does NOT have the groove of the carry loop next to it.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair a Popped-Off Owala Cap and Carry Loop: paso 6, imagen 1 de 2 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 6, imagen 2 de 2
      • Slide the other side of the wire into the hole on the other side of the lid.
      • This side of the lid should have the groove on the carry loop.
      • This step may require a bit of maneuvering.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Repair a Popped-Off Owala Cap and Carry Loop: paso 7, imagen 1 de 2 How to Repair a Popped-Off Owala Cap and Carry Loop: paso 7, imagen 2 de 2
      • Press the cap into the lid.
      • The groove on the carry loop will assist in pressing the cap into the lid.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Bethany Masum
Miembro Desde 10/09/25
145 Reputación
1 Guía escrita
Equipo
UC Davis, Team 2-1, Morris Fall 2025 Miembro de UC Davis, Team 2-1, Morris Fall 2025
UCD-MORRIS-F25S2G1
Miembros de 3
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 59
Ultimos 7 días: 284
Ultimos 30 días: 1,141
Todo El Tiempo: 3,424
