Saltar al contenido principal
How to Repair a Loose Rear Bicycle Wheel
Qué necesitas
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: paso 1, imagen 1 de 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: paso 1, imagen 2 de 3 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: paso 1, imagen 3 de 3
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: paso 2, imagen 1 de 2 How to Repair a Loose Rear Bicycle Wheel: paso 2, imagen 2 de 2
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: paso 3, imagen 1 de 2 How to Repair a Loose Rear Bicycle Wheel: paso 3, imagen 2 de 2
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: paso 4, imagen 1 de 2 How to Repair a Loose Rear Bicycle Wheel: paso 4, imagen 2 de 2
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: paso 5, imagen 1 de 2 How to Repair a Loose Rear Bicycle Wheel: paso 5, imagen 2 de 2
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: paso 6, imagen 1 de 3 How to Repair a Loose Rear Bicycle Wheel: paso 6, imagen 2 de 3 How to Repair a Loose Rear Bicycle Wheel: paso 6, imagen 3 de 3
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: paso 7, imagen 1 de 3 How to Repair a Loose Rear Bicycle Wheel: paso 7, imagen 2 de 3 How to Repair a Loose Rear Bicycle Wheel: paso 7, imagen 3 de 3
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
Conclusión
Lily Suggs
Miembro Desde 01/31/23
145 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-8, Andersen Winter 2023 Miembro de UC Davis, Team 4-8, Andersen Winter 2023
UCD-ANDERSEN-W23S4G8
Miembros de 3
1 Guía escrita
1Guía Comentario
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 48
Todo El Tiempo: 1,051
