Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to Repair a Locket Hinge
Qué necesitas
    1. How to Repair a Locket Hinge, How to Repair a Locket Hinge: paso 1, imagen 1 de 3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: paso 1, imagen 2 de 3 How to Repair a Locket Hinge, How to Repair a Locket Hinge: paso 1, imagen 3 de 3
      • Use pliers to carefully bend the damaged hinge back into place.
      • You want the hinge to be rounded and hollow, like a straw.
      • Test the hinge with some wire. If you can easily thread the wire through, then you can move on to Step 2. If not, keep bending.
      Pregunta a FixBot
      Agregar Comentario
    2. How to Repair a Locket Hinge: paso 2, imagen 1 de 3 How to Repair a Locket Hinge: paso 2, imagen 2 de 3 How to Repair a Locket Hinge: paso 2, imagen 3 de 3
      • Hold both ends of the wire.
      • Place the middle of the wire against a hard edge. Hold the wire so that it is perpendicular to the edge.
      • Straighten the wire by pulling it against the edge.
      Pregunta a FixBot
      Agregar Comentario
    3. How to Repair a Locket Hinge: paso 3, imagen 1 de 2 How to Repair a Locket Hinge: paso 3, imagen 2 de 2
      • Bend the wire to match the contours of your locket.
      • If your locket is rounded, your wire will have to be curved. If your locket is straight, your wire will have to be straight.
      Pregunta a FixBot
      Agregar Comentario
    4. How to Repair a Locket Hinge: paso 4, imagen 1 de 2 How to Repair a Locket Hinge: paso 4, imagen 2 de 2
      • Cut the wire to a manageable length. We suggest the length of the hinges plus some excess.
      Pregunta a FixBot
      Agregar Comentario
    5. How to Repair a Locket Hinge: paso 5, imagen 1 de 3 How to Repair a Locket Hinge: paso 5, imagen 2 de 3 How to Repair a Locket Hinge: paso 5, imagen 3 de 3
      • Match and align the front and back of the locket.
      • The holes of the hinge must be aligned, making a tunnel for the wire.
      • Line up the curved wire to match the locket shape.
      • Feed the wire through the hole of the hinge.
      Pregunta a FixBot
      Agregar Comentario
    6. How to Repair a Locket Hinge: paso 6, imagen 1 de 3 How to Repair a Locket Hinge: paso 6, imagen 2 de 3 How to Repair a Locket Hinge: paso 6, imagen 3 de 3
      • Hold the locket closed.
      • Glue the top of the hinge.
      • Glue the bottom of the hinge.
      • Do not glue the center of the hinge.
      Pregunta a FixBot
      Agregar Comentario
    7. How to Repair a Locket Hinge: paso 7, imagen 1 de 2 How to Repair a Locket Hinge: paso 7, imagen 2 de 2
      • Hold the locket closed and hammer the side with the hinge and wire.
      • Tap firmly along the hinge and wire to secure.
      Pregunta a FixBot
      Agregar Comentario
    8. How to Repair a Locket Hinge: paso 8, imagen 1 de 2 How to Repair a Locket Hinge: paso 8, imagen 2 de 2
      • Cut the excess wire.
      Pregunta a FixBot
      Agregar Comentario
    9. How to Repair a Locket Hinge: paso 9, imagen 1 de 2 How to Repair a Locket Hinge: paso 9, imagen 2 de 2
      • The final product, the locket hinge is fixed and the locket can be used.
      Pregunta a FixBot
      Agregar Comentario
Linea de Meta
Daisy J Williams
Miembro Desde 01/31/24
169 Reputación
1 Guía escrita
Equipo
UC Davis, Team 4-3, Andersen Winter 2024 Miembro de UC Davis, Team 4-3, Andersen Winter 2024
UCD-ANDERSEN-W24S4G3
Miembros de 3
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 66
Todo El Tiempo: 1,231
