Saltar al contenido principal
How to Repair a Knotted Chain
Qué necesitas
  1. How to Repair a Knotted Chain, How to Repair a Knotted Chain: paso 1, imagen 1 de 1
    • Find a flat surface.
    • Remove all clutter from your workspace to ensure you can access the chain easily.
    • The flat surface will provide stability when you begin working through the tangles and will prevent other tangles from forming during the process.
  2. How to Repair a Knotted Chain: paso 2, imagen 1 de 3 How to Repair a Knotted Chain: paso 2, imagen 2 de 3 How to Repair a Knotted Chain: paso 2, imagen 3 de 3
    • Rest the chain on the surface.
    • Slowly spread the chain out so you can recognize the tangled areas.
    • While spreading the chain on the surface, make sure to do so slowly in order to avoid tightening the tangle.
  3. How to Repair a Knotted Chain: paso 3, imagen 1 de 3 How to Repair a Knotted Chain: paso 3, imagen 2 de 3 How to Repair a Knotted Chain: paso 3, imagen 3 de 3
    • Unclasp the chain.
    • Separate the strands gently.
    • Opening the clasp will isolate the chain strands, permitting them to slide through the knots easily.
  4. How to Repair a Knotted Chain: paso 4, imagen 1 de 2 How to Repair a Knotted Chain: paso 4, imagen 2 de 2
    • Gently sprinkle baby powder onto the knotted area.
    • Sprinkle the powder until the knot is lightly coated.
    • This is an optional step.
  5. How to Repair a Knotted Chain: paso 5, imagen 1 de 3 How to Repair a Knotted Chain: paso 5, imagen 2 de 3 How to Repair a Knotted Chain: paso 5, imagen 3 de 3
    • Bring your thumb and index finger into a pinching pose.
    • Put the knot between the thumb and index finger.
    • Carefully and gently lightly rub the knot together.
  6. How to Repair a Knotted Chain: paso 6, imagen 1 de 2 How to Repair a Knotted Chain: paso 6, imagen 2 de 2
    • Insert two toothpicks between the focal point of the knot.
    • Any fine toothpick style tool can work to untangle the knot.
  7. How to Repair a Knotted Chain: paso 7, imagen 1 de 3 How to Repair a Knotted Chain: paso 7, imagen 2 de 3 How to Repair a Knotted Chain: paso 7, imagen 3 de 3
    • Gently draw the toothpicks from one another to open and release the tight knot.
    • When you get an opening in the knot using the toothpicks, take it apart by pulling each separated strand through the knot to fully open it.
    • Then slowly pull apart the loosened knot to separate the chain strands.
  8. How to Repair a Knotted Chain: paso 8, imagen 1 de 2 How to Repair a Knotted Chain: paso 8, imagen 2 de 2
    • Restore chain back into its original form.
    • Clasp the chain to avoid it from re-tangling.
  9. How to Repair a Knotted Chain: paso 9, imagen 1 de 2 How to Repair a Knotted Chain: paso 9, imagen 2 de 2
    • Wipe the chain with a damp towel or tissue before use.
Linea de Meta
2 personas más completaron esta guía.
Momena Masood
Miembro Desde 05/10/20
223 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 413
